where is the great Output Tool ?
brian_choy
I like to use the web Output Tool to analyse my "show tech" output from my router , all links point to blank page !!!
Any hints
Mark Malone
Hi here is the link to all tools including output , you will need to log in to website to use them
http://www.cisco.com/c/en/us/support/web/tools-catalog.html
Hi Mark,
Thanks for reply
I went to your link and sadly found :
Status: 302 Found Location: http://www.cisco.com/web/applicat/tsweb/403.html
Brian
Hi that's the only link alright you don't have the privilege to access it then sorry
If you cant your access approved I can run your show tech and send you the results if your stuck
