Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Hello, First of all, I apologize for using a translator to post this question. In our environment, when we need to change an AP’s IP address or hostname, or join it to a new controller, we usually connect it to a test WLC to make the changes before d...
Buenas tardes, me acaba de llegar un caso donde usuarios de apple acaban de actualizar sus iPhone a la versión de iOS 26 y después de esta versión ya no tienen navegación. No sé si hasta el momento han visto un comportamiento similar con esta versión
Hello Community,I am using cisco WLC 9800 and WLAN is configured to use Local dot1x authentication.where can i see the local users configured for this authentication.from GUI i am not able to find the local users section for this.Thanks in advance.
I have upgraded the firmware and successfully setup site-survey. The SSID is broadcasting, but I cannot login to the gui after setting up site-survey on a C9136I AP - admin/admin, Cisco/Cisco doesn't work. I factory reset the Ap and started over and ...
Trying to figure out the best way to set up a Cisco 3802E AP for our WLC environment. I was able to connect it to our WLC, but then noticed no Bridge/mesh option in WLC settings. Would be using this AP indoors, with external antenna above structure ...
Hello All,Greetings!I am planning to have a SSID named SSID1 & VLAN group range 201 to 205 assigned to this SSID in WLC C9800. among these vlan I want VLAN 201, the devices I want to assign IP statically should fall in this VLAN. 202 to 205, the devi...
Hi, one of my 2802i refuses to join my WLC. On console all CAPWAP config commands fail with "Capwap process not ready yet. Try after few moments." AP00F2.8B27.AD68#show capwap client config AdminState : ADMIN_ENABLED(1)Name : AP00F2.8B27.AD68Locati...
I need to order several Cisco C9120AXE models with antenna model AIR-ANT2544V4M-RS. I am planning to make these APs join the WLC of model 5520 which is already operational in my network. In the AIR-ANT2544V4M-RS datasheet, i see the below note, "The ...
Hi Guys,We recently replaced our APs to C9120 model, and they are joined to C9800 WLC. However some old clients who have WiFi 3 WLAN card are having issue, they lost wireless connection for a second and re-connected automatically. This issue happends...
I am using C9800-CL in redundancy.with xxx.xxx.xxx.1 - Core-WLC.com xxx.xxx.xxx.2 - Primary xxx.xxx.xxx.3 - SecondaryWhen I try to use " Core-WLC.com " after entering username and password it gives me error as {"text" : "nil response from WSMA"} or V...
Hey all. I work in a warehouse and we have 18 APs all connected to an AIR-CT3504-K9 controller. We have one spot within our warehouse where we have some PCs that are between a modular office and the bathrooms. The ceiling is really high up (maybe ...
Output of wireless related show commands like 'show wireless client summary detail', 'show ap dot11 5ghz summary', or 'show ap summary' on the 9800 CLI is very slow. It takes ~42 seconds to display data on ~2700 clients on a 9800-40 if you disable pa...
Could everyone reading this with Catalyst AX series APs and a 9800 WLC do "show ap slots" and look for APs that have the slot 1 radio showing up as "802.11b/g" ? For example an affected AP will look like this in the output of "show ap slots":ap-name ...
CW9172I has increased cabling sensitivity and experiences PoE detect issues in some cases when connected to cat6 that is within specification according to cable analyzer results. This manifests itself in the AP failing to be detected by the PSE for h...
Hi Team, We have pair of 5508 controller in SSO . We want to test AP failover through ACL applying on WLC. When we created ACL and applied on WLC GUI / CLI we are getting error "Changing the managment ACL is blocked when system is in redundancy state...
