cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
CWA captive portal does not finish the connection process
Promerob08
Team,
I need support, I have a CWA configuration in ISE 3.3 patch 2 with a WLC C9800-CL 12.9.5 firmware, I have
doubts with the ACL at WLC and the policies in ISE, there are hits in the "redirect login" policy but it
does not reach the " Guest Flow" so the authentication process does not finish. I attach screenshots.
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Promerob08
case solved.
The cause was due to a policy order, after the redirect instead of landing on "access portal" it went to another 802.1x.
Ver la solución en mensaje original publicado
1 RESPUESTA 1
Promerob08
case solved.
