cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Help
rodrigomeira
Visitor
I need some help, I'm going to replace the access points in my campus environment, and I need an outdoor model from Cisco with virtualized controller, I don't want hardware. I'm considering the C9124AXE-x model. Can anyone assist me if the virtual controller actually exists?
3 RESPOSTAS 3
 The part number you need is :
  C9124AXI-EWC-X: Cisco Catalyst 9124AX Series Access point with Embedded wireless controller (internal omnidirectional antenna)
 ●  C9124AXD-EWC-X: Cisco Catalyst 9124AX Series Access point with Embedded wireless controller (internal directional antenna)
 ●  C9124AXE-EWC-X: Cisco Catalyst 9124AX Series Access point with Embedded wireless controller (External Antenna)
Sure, do I need any license for it to function? If I buy 10 of these antennas, will I be able to manage all of them in a single system?
You dont need license. But you should have at least one C9124AXI-EWC-X in order to run the WLC.
