取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
评论
samirpast
Cisco is committed to interoperability between Cisco TelePresence products and competitive multiscreen video communications devices. Cisco TelePresence interoperability initiatives as well as recent milestones include:
  • Leading industry standards development organizations efforts to develop specifications. A future suite of specifications will make up the multi-stream, telepresence standard for interoperability.
  • Opened up Telepresence Interoperability Protocol (TIP). Cisco has opened up and transferred its Telepresence Interoperability Protocol (TIP) to the International Multimedia Telecommunications Consortium (IMTC) to license royalty-free to anyone. Those wanting a multi-stream interoperability option with Cisco now can implement TIP as well as participate in its ongoing stewardship as a member of IMTC.
  • Launched a TIP Library Open Source project. To help speed your implementation of TIP, Cisco has also launched a TIP Library open source projectThis has also been transferred to IMTC and is offered under the Apache 2.0 License.
What is in TIP
The TIP protocol specifications describe how to multiplex multiple screens, multiple audio streams, as well as an auxiliary-data screen into a single Real-Time Transport Protocol (RTP) flows, one each for video and audio. It enables point to point and multipoint sessions as well as a mix of multi-screen and single-screen endpoints.
The TIP protocol specification also defines how RTP Control Protocol (RTCP) - APP extensions are used to indicate profile capabilities and per media flow options as a session is established.  It also defines how devices can provide feedback and trigger resiliency mechanisms during the life of the streams.
Getting Started on a TIP Implementation
First, go to the IMTC web page for TIP. There you will find both version 6 and version 7 of the TIP protocol available under both evaluation and full implementation licenses from IMTC. IMTC will also be facilitating TIP product interoperability testing events and hosting ongoing discussions around enhancements or changes needed to TIP to help ensure multi-vendor success.
Second, consider using the TIP Library open source to kick start the integration of the TIP protocol in your device(s). Please consider joining the project to help make enhancements or code contributions towards supporting future versions of TIP.
Third, read through the Cisco TIP Implementation Profiles listed below. These profiles explain what options Cisco TelePresence devices can accept among those defined the TIP specification. Additional ancillary information needed to achieve interoperability is also included, such as what call control messaging is required and how to establish encrypted channels. These will be updated as needed for clarity or corrections and additional versions may be published from time to time as the Cisco TelePresence products evolve or as software releases enable new options.
Cisco 1.6b single screen profile (TIP v6)with Full Licensewith Evaluation License
Cisco 1.6b triple screen profile (TIP v6)with Full License with Evaluation License
Cisco 1.7 endpoint profiles (TIP v7)with Full License with Evaluation License
Cisco 1.8-1.10 endpoint profiles (TIP v7 and TIP v8)with Full License with Evaluation License
Cisco TX 6.0 endpoint profile supplement (TIP v7 and TIP v8)with Full License with Evaluation License
Cisco IX 8.0 endpoint profile supplement (H.265 codec in TIP v8)with Full License with Evaluation License
To receive notices on updated Cisco TIP information, please subscribe.
Cisco Products with TIP Support
Product FamilyTIP v6TIP v7TIP v8
Cisco Meeting Server--Version 2.0 or later.
Cisco TelePresence System endpoints (500, 1100, 1300, 3200, 9000 and 5000 etc)Release 1.6.5 and later releases for the CTS Series.Release 1.7.0 and later releases for the CTS Series. Releases TX 6.0 and IX 8.0 or later for the TX and IX Series respectively.Release 1.10 for the CTS Series. Releases TX 6.0 and IX 8.0 or later for the TX and IX Series respectively.
Cisco TelePresence Multipoint SwitchRelease 1.6.4 or laterRelease 1.7 or laterNot supported
Cisco TelePresence ServerRelease 2.1 or laterRelease 2.2 or laterVersion 3.0(2.46) or later. Prefer BFCP Support added in version 3.1
To learn more about Cisco software releases, please see the Cisco TelePresence Administration Software Release and General Information page.
TIP Commitments Monitoring Trustee Information
Some of the initiatives around TIP taken above are the subject of commitments Cisco made to the European Commission, which reviewed Ciscoa
具体文档连接:https://www.cisco.com/c/en/us/about/telepresence-interoperability-protocol-developers.html
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
