取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
6
回复
ASA5512,10兆光纤,网速慢了。
weritbrid
之前关于网络不通,是正常的,只是要重新启动防火墙,光猫。就正常了。
添加了防火墙之后,网速变慢了。是不是哪里受限制了网速。
代码如下:
ciscoasa# show run
: Saved
ASA Version 8.6(1)2
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
description connecion to Isp
nameif outside
security-level 0
ip address 211.154.130.101 255.255.255.192
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
object network inside_network
subnet 192.168.0.0 255.255.255.0
object network yixinda_server
host 192.168.0.3
object network yixinda_13335
host 192.168.0.3
object network yixinda_13681
host 192.168.0.3
object network yixinda_13682
host 192.168.0.3
object network lijing_server
host 192.168.0.2
object network lijing_1986
host 192.168.0.2
object network lijing_8081
host 192.168.0.2
object network lijingdataserver
host 192.168.0.4
object network lijingdataserver_1987
host 192.168.0.4
access-list out-to-in extended permit icmp any any
access-list out-to-in extended permit tcp any object yixinda_server eq 13335
access-list out-to-in extended permit tcp any object yixinda_server eq 13681
access-list out-to-in extended permit tcp any object yixinda_server eq 13682
access-list out-to-in extended permit tcp any object lijing_server eq 1986
access-list out-to-in extended permit tcp any object lijing_server eq 8081
access-list out-to-in extended permit tcp any object lijingdataserver eq 1987
pager lines 24
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
nat (inside,outside) static interface service tcp 13335 13335
nat (inside,outside) static interface service tcp 13681 13681
nat (inside,outside) static interface service tcp 13682 13682
nat (inside,outside) static 211.154.130.100 service tcp 1986 1986
nat (inside,outside) static 211.154.130.100 service tcp 8081 8081
nat (inside,outside) static 211.154.130.100 service tcp 1987 1987
access-group out-to-in in interface outside
route outside 0.0.0.0 0.0.0.0 211.154.130.102 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect icmp
service-policy global_policy global
prompt hostname context
call-home reporting anonymous prompt 2
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly 13
subscribe-to-alert-group configuration periodic monthly 13
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:14c21bb3663f90f5fc23672693de22ad
: end
6 条回复6
hanren
是哪里到哪里的网络不通
weritbrid
hanren 发表于 2014-5-27 13:45 back.gif
是哪里到哪里的网络不通
通过防火墙PING192.168.0.3 网络是通的。在用电脑PING192.168.0.1 ,PING不通。是什么原因
hanren
是从外网ping不通 192.168.0.1吗
做了pat 所以ping不通
nat(inside,outside) dynamic interface
764963038cisco
你是从哪到哪不通?
lin-fayong
ICMP permit inside
Binbin Liu
网速变慢了,你是用什么软件测速的啊?
不同的测速软件使用的协议是不一样的。
之前碰到个用户测速,使用的360测速,360使用的是UDP流。
speed test 是使用的TCP流。
建议您用下speed test测速,www.speedtest.net
快捷链接
