Hi friends,
I have a FPR-3110 with single power.
It was very noisy in my demo lab.
I tried to change the fan speed and found only two options and got an error.
Demo-dfffsdfDCCCC(local-mgmt)# config fan-speed
Enter a 1 to enable maximum fan speeds
Fan lifetime may be shortened if left
on the maximum setting for extended periods.
Set fan speed mode to maximum [1],
to automatic control [0],
or [x] to exit: 0
Password:
Unsupported platform 12
Fan speed set to automatic control.
Configuration Successful
or [x] to exit: 0
Password:
Sorry, try again.
Password:
Unable to take fan speed control from FPGA
Error setting Fan 0 to max speed
Error setting Fan 1 to max speed
Error setting Fan 2 to max speed
Error setting Fan 3 to max speed
Unable to set fan LED to fast blink
Is anyone in the same situation as me? How to solve it
Not that i am aware you can change that speed.
can you post
# show environment summary
thanks for you reply.
There is no such command in local administration mode. I collected other commands
Demo-dfffsdfDCCCC(local-mgmt)# show env basic
*************** Chassis Temps ***************
AD7416_INTERNAL_TEMP_1 is 26 degrees Celsius
AD7416_INTERNAL_TEMP_2 is 27 degrees Celsius
*************** CPU Data ***************
Core Temperature 0 is 35 degrees Celsius
Core Temperature 1 is 35 degrees Celsius
Core Temperature 2 is 35 degrees Celsius
Core Temperature 3 is 35 degrees Celsius
Core Temperature 4 is 35 degrees Celsius
Core Temperature 5 is 35 degrees Celsius
Core Temperature 6 is 35 degrees Celsius
Core Temperature 7 is 35 degrees Celsius
Core Temperature 8 is 35 degrees Celsius
Core Temperature 9 is 35 degrees Celsius
Core Temperature 10 is 35 degrees Celsius
Core Temperature 11 is 35 degrees Celsius
*************** Power Supplies ***************
PSU 1 input is okay
PSU 1 output is okay
-- Power Supply 1
Voltage In : 0xf9ca Raw Hex
Current In : 0xe805 Raw Hex
Power In : 0x1023 Raw Hex
Temperature 1 : 0x0020 Raw Hex
Temperature 2 : 0x001e Raw Hex
Temperature 3 : 0x0022 Raw Hex
Fan Speed : 0x2870 Raw Hex
Fan Status : 0x00 Raw Hex
Voltage Out : 0x0078 Raw Hex
Current Out : 0x0066 Raw Hex
Power Out : 0x101e Raw Hex
No detected PSU in PSU Slot 2
*************** EPM Data ***************
*************** Fans ***************
FanMod 1 Fan 1 rotating
FanMod 1 Fan 1 RPM = 16740
FanMod 1 Fan 2 rotating
FanMod 1 Fan 2 RPM = 16740
FanMod 1 Fan 3 rotating
FanMod 1 Fan 3 RPM = 16740
FanMod 1 Fan 4 rotating
FanMod 1 Fan 4 RPM = 16740
FanMod 2 Fan 1 rotating
FanMod 2 Fan 1 RPM = 16860
FanMod 2 Fan 2 rotating
FanMod 2 Fan 2 RPM = 16860
FanMod 2 Fan 3 rotating
FanMod 2 Fan 3 RPM = 16800
FanMod 2 Fan 4 rotating
FanMod 2 Fan 4 RPM = 16800
Fan Controller Speed = automatic
Demo-dfffsdfDCCCC# show chassis environment fan detail
Chassis 1:
Overall Status: Operable
Operability: Operable
Power State: Ok
Thermal Status: Ok
Tray 1 Module 1:
Power State: On
Fan 1:
Power State: On
Fan 2:
Power State: On
Fan 3:
Power State: On
Fan 4:
Power State: On
Tray 1 Module 2:
Power State: On
Fan 1:
Power State: On
Fan 2:
Power State: On
Fan 3:
Power State: On
Fan 4:
Power State: On
