取消
显示结果
搜索替代
您的意思是:
查看次数
20
有帮助
回复
又来请教,瘦ap 1702I-H-K9配置
daijy
用lwapp ap命令配置了自身ip、网关以及controller的ip了,ping网关和控制器都通,就是在ac上看不到,然后一直提示translatting cisco-capwap-controller...domain server 255.255.255.255。而且在配置ap自身静态ip时,也提示should config DNS from controller CLI/GUI。。。。感觉是隧道没建立。这可咋办?
对了,还有,我前几次的帖子悬赏要怎么给到回复我的哥哥们?
1 个已接受解答
已接受的解答
1、LAP上手动输入的配置命令是什么呢?
2、WLC上的show信息:
show time
show run-config
show msglog
3、WLC和LAP的debug:
3.1-WLC上debug:
WLC> debug mac addr < AP MAC address >
WLC> debug capwap errors enable
WLC> debug capwap events enable
WLC> debug dtls all enable
关闭使用命令debug disable-all
3.2、AP上debug:
AP# debug capwap client event
AP# debug capwap client error
AP# debug dtls client error
AP# debug dtls client event
使用命令un all关闭
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
在原帖中查看解决方案
5 条回复5
2、WLC上的show信息:
show time
show run-config
show msglog
3、WLC和LAP的debug:
3.1-WLC上debug:
3.2、AP上debug:
使用命令un all关闭
daijy
以下是我show的一些信息:
AP> show ip inter b
BVI1 *.*.*.* YES TFTP up up
GigabitEthernet0 unassigned NO unset up up
GigabitEthernet1 unassigned NO unset administratively down down
AP> show capwap i c
LWAPP Static IP Configuration
IP Address *.*.*.*
IP netmask 255.255.255.0
Default Gateway *.*.*.*
Primary Controller *.*.*.*
AP# dir
Directory of flash:/
2 -rwx 1048 Mar 1 1993 00:00:21 +00:00 private-multiple-fs
4 -rwx 0 Mar 1 1993 00:00:35 +00:00 config.txt
5 -rwx 307 Mar 1 1993 00:04:11 +00:00 env_vars
38 drwx 576 Jan 1 1970 00:12:13 +00:00 ap3g2-rcvk9w8-mx
48 drwx 2496 Jan 1 1970 00:18:19 +00:00 ap3g2-k9w7-mx.153-3.JD
40900608 bytes total (20188160 bytes free)
以下是AP启动时的输出信息:
cisco AIR-CAP1702I-H-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FGL2145AF1X
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.3.102.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: *******
Part Number : *******
PCB Serial Number : *******
Top Assembly Part Number : *******
Top Assembly Serial Number : *******
Top Revision Number : *******
Product/Model Number : AIR-CAP1702I-H-K9
% Please define a domain-name first.
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
Press RETURN to get started!
*Mar 1 00:00:14.371: Starting Ethernet promiscuous mode
*Mar 1 00:00:14.375: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:00:14.375: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar 1 00:00:15.679: %LWAPP-4-CLIENTEVENTLOG: PnP waiting for capwap init
*Mar 1 00:00:15.679: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:16.419: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JD, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 29-Jul-16 04:10 by prod_rel_team
*Mar 1 00:00:16.419: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar 1 00:00:16.471: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar 1 00:00:16.475: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER inline power source
*Mar 1 00:00:17.467: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:18.475: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
*Mar 1 00:00:21.059: DPAA Initialization Complete
*Mar 1 00:00:21.059: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:22.059: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:24.059: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:25.059: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar 1 00:00:28.467: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:00:28.487: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:00:28.487: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar 1 00:00:28.487: spamInitRadCfg: recovery image default mode 0
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:28.651: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:29.467: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
bridge-group 1 source-learning
% Invalid input detected at '^' marker.
*Mar 1 00:00:35.375: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:00:35.375: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar 1 00:00:35.375: %CAPWAP-3-EVENTLOG: No Config Present. PNP required
*Mar 1 00:00:35.379: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
%Error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)creating PnP template view
HaifengLi
版本是RCVK9W8,所以需要刷才能正常使用(有信号)。
WLC是什么型号和版本?
建议贴出debug capwap信息
daijy
WLC是什么型号和版本?
感谢!我现在另一个项目上,等我看了是什么型号以及debug capwap后回复您。
daijy
WLC是什么型号和版本?
WLC型号是AIR-CT5508-K9,软件版本是7.6.100.0
快捷链接
