取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
请教AP1832i Mobility Express主页无法打开问题
manRyan60924
前两天想把AP1810W刷成胖模式(ME),没成功。转头研究AP1832I,又出现问题,再开贴咨询……AP1832I,已从官网下载8.8,8.7和8.2三个版本ME固件,使用Console线,自建TFTP服务器,刷新成功。
1)最开始刷8.7固件,刷新完成后,提示连接CiscoAirProvision。
可实际并没有 CiscoAirProvision。等待了20分钟,红黄绿三色交替,CLI界面无提示。确实没有任何信号,尝试隐藏网络, 也不能成功。
2)再次尝试8.8.100和8.8.111两个固件,刷新完成,依旧没有CiscoAirProvision。
8.7,8.8反反复复刷了几遍都是这样。
3)从别的地方找到一个8.2固件,刷新完,终于出现CiscoAirProvision。
使用192.168.1.1地址登录Web页面成功,首次保存后,能有信号,能够使用。
4)按照教程,连接新建的SSID,网络连通。
但ME的管理界面连接不上。换过浏览器,换过管理地址,设备IP跟管理IP是同一网段。Console上AP,Ping电脑。电脑Ping AP的ME管理地址都能Ping通。但就是显示404……
:D
10 条回复10
你好:
部署ME的时候,需要注意:
1、You must not have other Cisco wireless controllers, neither appliance nor virtual, in the same network, during set up or daily operation of a Cisco Mobility Express network.
2、Configure a DHCP server on the switch or externally so that Cisco 1800 series Access Point can obtain an IP address at boot up. The DHCP server also assigns IP address to other APs and wireless clients.
3、Configure a TFTP server which can be accessed from the Management interface of Mobility Express. Save the AIR--K9-.tar and AIR--K9-ME-.zip file (unzipped)on the TFTP server.
4、Decide on the first AP to set up. The first AP to setup must support Cisco Mobility Express controller functionality. You can also connect multiple Cisco 1800 series Access Points running Mobility Express to the switch.
5、If your network is using universal regulatory domain access points, then you need to prime the access point to the right regulatory domain, before the APs start serving clients. For more information, see Cisco Aironet Universal AP Priming and Cisco Air Provision User Guide, at this URL:
http:/​/​www.cisco.com/​c/​en/​us/​td/​docs/​wireless/​access_point/​ux-ap/​guide/​uxap-mobapp-g.html
6、A Wi-Fi-enabled laptop with G Band to connect to the pre-defined CiscoAirProvision SSID. The laptop needs to have a compatible browser. For a list of browsers compatible with the with the Cisco Mobility Express wireless LAN controller web interface and the initial configuration wizard, see .
请问管理地址是否可以ping通?
你是通过HTTP还是HTTPS连接ME管理界面呢?默认情况下HTTP应该是关闭的,HTTPS默认开启,也可以使用命令show network summ检查一下。
通过有线连接可以打开GUI界面吗?
如果可以登录到AP的CLI界面,可以看看如下信息:
Controller CLI:show interface detailed management
使用命令apciscoshell,进入AP的console,再使用show ip int br看看wired0的接口IP地址
确认Controller和AP的IP地址不同。
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
mingzeng
根据描述您当前无线网络已经可以正常使用,但无法打开web图形化管理。
1. 您可以查看webmode是否开启此项功能,因为默认此项功能关闭。show network summary可查看。将其功能开启即可。
2. 后续如依旧无效,您可以尝试开启debug配合抓包查看http/https流量是否正常。
敏民
换台电脑...我也曾经遇到过1852刷了ME后.就是打不开WEB界面..显示404...后来换了一台电脑.有可能是装了简化版W7系统.或者浏览器是简化版.....用2345浏览器成功的
manRyan60924
收到,感谢几位。好事多磨,下周一再尝试下。:handshake
楼主楼主,问题是否有了新的进展,可以分享一下哦~
manRyan60924
昨天莫名的好了……我在CLI界面无法退出APCiscoShell,logout 几次以后还在AP模式,我就又用8.2.166.0固件重刷了一次。
连接CiscoAirProvision后,在初始192.168.1.1界面,简单配置了,管理地址,SSID等,存盘重启。
使用POE交换机供电,只连接这一台AP,未上联设备。
重启后等待30分钟,CLI界面一直提示,waiting for uplink IP address and reachable default gateway
无WIFI广播。
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... d4:ad:bd:6a:42:60
IP Address....................................... 192.168.1.20
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.1.1
(Cisco Controller) >show network summary
RF-Network Name............................. default
DNS Server IP............................... 127.0.0.1
Web Mode.................................... Disable
大概过了两个多小时,忙了点儿别的事情,还是没有WIFI信号(CiscoAirProvision和我新配的都没有)。
本着死马当活马医的态度,上联口接入公司网络,(公司有DHCP,DNS Server,无线控制器)。
随即就提示
[*02/17/2020 08:15:22.9959] ethernet_port wired0, ip 10.116.X.X, netmask 255.255.X.0, gw 10.116.X.X, mtu 1500, bcast 10.116.X.X, dns1 10.116.X.X, domain ... ...【无意义的数字用"X"代替了】
[*02/17/2020 08:15:23.5458] DOT11_DRV[0]: set_channel Channel set to 6
[*02/17/2020 08:15:23.5458] DOT11_DRV[0]: Channel set to 6, width 20
[*02/17/2020 08:15:23.5558] DOT11_DRV[0]: Channel set to 6, width 20
[*02/17/2020 08:15:23.5658] DOT11_DRV[1]: set_channel Channel set to 36
[*02/17/2020 08:15:23.5658] DOT11_DRV[1]: Channel set to 36, width 20
[*02/17/2020 08:15:23.5758] DOT11_DRV[1]: Channel set to 36, width 20
[*02/17/2020 08:16:03.2534] chatter: tohost_virtual :: ToHost: device 'virtual' went down
Cryptographic library self-test....
Testing SHA1 Short Message 1
Testing SHA256 Short Message 1
SHA1 POST PASSED
passed!
从DHCP上获得IP地址DNS等信息,过了一会儿我刚配置的WIFI就出现了。
我用笔记本无线连接WIFI,登录上面配的管理地址,竟然就可以了……
同一台笔记本,同样的浏览器IE和谷歌,以前无数次都是这么配的,Web Mode依旧是 Disable,但确实能用了。
今天我把固件升级到8.8.100,有中文界面了。
总结,这次状况。
1)首先是自己的技术不足,手里管理着两台无线控制器和一两百台AP,都是最简单的管理,设备接入,改名,加Group,依赖无线控制器。
后续还要加强学习。
2)镜像或者调试用设备有问题。
没有CCO账号,镜像都是在各论坛,百度云下载的,下载后也没有验证MD5,不排除镜像有问题。
(今天下载页面显示不了,输入用户名密码后直接提示出现错误,前两天还能看到固件版本页面,下载时才提示没有权限)
感谢@ @ @ 几位大神,以及管理员热心回帖和帮助。
这两周在配合公司 协调,完成复工等工作。后面腾出时间我准备尝试通过无线网桥方式连接AP,以及接入ME或无线控制器。
可能实际使用价值不大,就是一种尝试吧。
ccccc52791
楼主,我也有一台1832,能请教一些问题吗?我这台应该是带C的,默认应该是ME模式。但是我第一次连接完WIFI配置相关配置自动重启后,SSID跟web就消失和访问不进去了。请问要怎么解决啊?
HaifengLi
ccccc52791 发表于 2020-3-30 18:10
楼主,我也有一台1832,能请教一些问题吗?我这台应该是带C的,默认应该是ME模式。但是我第一次连接完WIFI配 ...
这种很可能和AP join或country code有关
sufee
值得学习一下!
敏民
看你描述.ME网络环境只能1个主控制器.....你应多看思科社区秦柯老师的公开课视频,己经讲的很详细
快捷链接
