取消
显示结果
搜索替代
您的意思是:
查看次数
50
有帮助
13
回复
请教LAP1142N-K9从瘦模式升级到胖模式的具体过程
kokuquka91463
各位大侠,小弟菜鸟一个,朋友那边拿回一个1142N,想用做桥接AP,无奈不会设置,网上找了很多资料,
  • 按住MODE键,再插入电源开机。
  • 出现button is pressed, wait for button to be released...时松开MODE键,已经进Xmodem模式。
  • 在出现AP:后
  • 输入EN回车,就出现Unknown cmd:en
  • 输入其他设置都没用,不知道哪位高手能否支援一下,最好是详细点的过程,小弟感激不尽!
13 条回复13
cisco.feng
不需按mode physical button
正常开机即可
kokuquka91463
直接开机,使用超级连接后显示这个样子了
flashfs[0]: 69 files, 15 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 21147136
flashfs[0]: Bytes available: 11237888
flashfs[0]: flashfs fsck took 26 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 50:57:a8:ca:d3:ed
Waiting for PHY auto negotiation to complete... TIMEOUT !
Ethernet link is down.
flashfs[2]: 69 files, 15 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 32126976
flashfs[2]: Bytes used: 21147136
flashfs[2]: Bytes available: 10979840
flashfs[2]: flashfs fsck took 8 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 1 seconds.
flashfs[4]: Initialization complete....done Initializing flashfs.
Radio0 present 8363 8000 90020000 0 90030000 B
Rate table has 300 entries (16 legacy/64 11n/220 11ac)
POWER TABLE FILENAME = flash:/c1140-k9w8-mx.153-3.JA10/T2.bin
Radio1 present 8363 8000 98020000 0 98030000 0
POWER TABLE FILENAME = flash:/c1140-k9w8-mx.153-3.JA10/T5.bin
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1142N-C-K9 (PowerPC405ex) processor (revision B0) with 98294K/32768
K bytes of memory.
Processor board ID FGL1612S3DP
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from watchdog timer expired
LWAPP image version 8.0.140.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 50:57:A8:CA:D3:ED
Part Number : 73-12836-04
PCA Assembly Number : 800-33767-04
PCA Revision Number : A0
PCB Serial Number : FOC16103BAA
Top Assembly Part Number : 800-33775-03
Top Assembly Serial Number : FGL1612S3DP
Top Revision Number : A0
Product/Model Number : AIR-LAP1142N-C-K9
% Please define a domain-name first.
Press RETURN to get started!
kokuquka91463
开机后,超级连接后显示这样了
huajianshoes
你刷机没有成功
1、下载3CDaemon软件,用做于TFTP服务器
2、下载此AP的胖固件,例:c1140-k9w7-tar.153-3.JBB4.tar
3、把固件放到3CDaemon根目录,改名ap1g2-k9w7-tar.default
4、配置电脑IP10.0.0.X(只要不是10.0.0.1就行),掩码255.0.0.0
5、启动3CDaemon前先打开“设置TFTP服务器”,检查上传下载目录对不对,没有问题了再启动
6、AP与电脑必须接在同一个交换机(vlan相同,必须广播能收到)
7、按住AP的MODE键不放,插入网线(POE)。。直到灯变成红色不闪后,,再等几秒松手。。
不出意外的话就开始下载固件了
YilinChen
huajianshoes 发表于 2019-6-14 16:46
你刷机没有成功
2、下载此AP的胖固件,例:c1140-k9w7-tar.153-3 ...
楼上已经说得很完整了,另外可以通过3CDaemon窗口,可以观察到AP是否开始下载固件;
kokuquka91463
多谢!多谢了,自己再试试看!
kokuquka91463
还是没有搞定啊,继续求助!
1,设置10.0.0.2 IP地址
2,设置TFTP服务器
服务器地址10.0.0.1
文件C:\3CDaemon\c1140-k9w7-tar.default
3:连接网线和CONSOLE线到电脑COM口
4:按住Model键不放,接通AP电源,终端出现button is pressed,wait for button to bereleased后,再保
持20秒松手
5:出现了以下提示,继续不下去了,不知道哪里出错了examining image...
%Error opening tftp://255.255.255.255/c1140-k9w7-tar.default (connection timed o
ut)
ap:
kokuquka91463
kokuquka91463
难道是要把c1140-k9w7-tar.153-3.JD16整个压缩文件名称改为c1140-k9w7-tar.default吗?
还是解压缩之后的c1140-k9w7-xx.153-3.JD16改为c1140-k9w7-tar.default?
liyanazure
瘦AP(LWAPP)转胖AP(Autonomous)
1. 镜像使用正常镜像
例:使用的镜像类型为c1140-k9w7-tar.124-21a.JY.tar<<<<<需使用非recovery镜像
2. TFTP连接
TFTP服务器网线连接LWAPP
Console连接LWAPP
AP#config terminal
AP(confg)#interface fastethernet 0
AP(confg-if)#ip address <<<<<<<<<<<需和笔记本网卡同一网段
AP(confg-if)#end
3. AP开启debug
AP>enable
AP#debug lwapp console cli
AP#debug capwap console cli
4. 传输镜像
命令:AP#archive download-sw /force-reload /overwrite tftp:///
例:AP#archieve download-sw /force-reload /overwrite tftp://10.0.0.5/c1140-k9w7-tar.124-21a.JY.tar
raoshine
还是解压缩之后的c ...
直接改名称和后缀
张瑞鹏
你的问题,我可以回答。
还是按住mode启动,在显示button is press 这时候松开
直到启动到ap>这个提示符下。
然后这时候,AP不会自动找tftp上的映像,所以自己需要手工拷贝过去
这条命令 copy tftp://10.0.0.2/ap2g1.k9w8xxxxxxx.default flash://xxxxxx.default
当然这一步的前提就是你的tftp服务器是开启状态,把上面的ip替换为你的ip,把文件名替换为你的映像的文件名即刻。
复制完成后,boot命令重启。
然后就进入到新的系统了
如果还搞不定,可以联系我的Q45185852
jasonzhan3151
kokuquka91463 发表于 2019-6-20 23:15
还是没有搞定啊,继续求助!
1,设置10.0.0.2 IP地址
2,设置TFTP服务器
tftp服务器地址是你的电脑的地址,如果你的tftp是在电脑上的话
第二,你的电脑不能设10.0.0.1,因为这是ap刷胖的时候的默认地址
你电脑设成10.0.0.2吧
快捷链接
