本帖最后由 qq244895656 于 2015-10-6 17:59 编辑 process '/usr/bin/gettyOrMwar' (pid 1279) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1280) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1281) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1282) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1283) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1284) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1285) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1286) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1287) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1288) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1289) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1290) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1291) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1292) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1293) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1294) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1295) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1296) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1297) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1298) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1299) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1300) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1301) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1302) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1303) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1304) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1305) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1306) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1307) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1308) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1309) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1310) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1311) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1312) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1313) exited. Scheduling it process '/usr/bin/gettyOrMwar' (pid 1314) exited. Scheduling it WLCNG Boot Loader Version 1.0.20 (Built on Jan 14 2014 at 11:40:45 by cisco) Board Revision 1.3 (SN: FCW1742L00Q, Type: AIR-CT5508-K9) (P) Verifying boot loader integrity... OK. OCTEON CN5645-NSP pass 2.1, Core clock: 600 MHz, DDR clock: 330 MHz (660 Mhz data rate) FPGA Revision 1.7 Env FW Revision 1.8 USB Console Revision 2.2 CPU Cores: 10 DRAM: 1024 MB Flash: 32 MB Clearing DRAM........ done Network: octeth0', octeth1 ' - Active interface E - Environment MAC address override CF Bus 0 (IDE): OK IDE device 0: - Model: STEC M2T CF 1.0.0 Firm: K1367MIX Ser#: STIM2Q2213263091433 - Type: Hard Disk - Capacity: 977.4 MB = 0.9 GB (2001888 x 512) Press now to access the Boot Menu... ============================================================ Boot Loader Menu ============================================================ 1. Run primary image (8.0.120.0) 2. Run backup image (8.0.120.0) - Active 3. Change active boot image 4. Clear configuration 5. Format FLASH Drive 6. Manually update images ------------------------------------------------------------ 5508主备系统是8.0.120.0 现在进不去了,一直卡在process '/usr/bin/gettyOrMwar' (pid 1282) exited. Scheduling it 这个状态,有什么好的办法解决?或者 WLC 得什么病了?
