取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
19
回复
AP无法发出5G信号
wuhao0015
各位手头有两个1810W,目前发现5G信号发不出来,在设备上看状态貌似正常。用客户端inssider扫描不到5g,客户端也只能连接到2.4g。
使用控制器版本为8.3.150,8.5.161,16.12.3都试过,都发不出5g,想请教各位看下是否是硬件问题?
WLC#show ap dot11 5ghz summary
AP Name Mac Address Slot Admin State Oper State Width Txpwr Channel
AP00A2.890E.24B0 00a2.890e.f920 1 Enabled Up 40 *1/8 (18 dBm) (36,40)*
AP00A2.8912.50B8 00a2.8913.aaa0 1 Enabled Up 40 *1/8 (18 dBm) (36,40)*
WLC#
WLC#
WLC#
WLC#show ap dot11 5ghz network
802.11a Network : Enabled
11nSupport : Enabled
802.11a Low Band : Enabled
802.11a Mid Band : Enabled
802.11a High Band : Enabled
802.11a Operational Rates
802.11a 6M : Unsupported
802.11a 9M : Supported
802.11a 12M : Mandatory
802.11a 18M : Supported
802.11a 24M : Mandatory
802.11a 36M : Supported
802.11a 48M : Supported
802.11a 54M : Supported
802.11n MCS Settings:
MCS 0 : Supported
MCS 1 : Supported
MCS 2 : Supported
MCS 3 : Supported
MCS 4 : Supported
MCS 5 : Supported
MCS 6 : Supported
MCS 7 : Supported
MCS 8 : Supported
MCS 9 : Supported
MCS 10 : Supported
MCS 11 : Supported
MCS 12 : Supported
MCS 13 : Supported
MCS 14 : Supported
MCS 15 : Supported
MCS 16 : Supported
MCS 17 : Supported
MCS 18 : Supported
MCS 19 : Supported
MCS 20 : Supported
MCS 21 : Supported
MCS 22 : Supported
MCS 23 : Supported
MCS 24 : Supported
MCS 25 : Supported
MCS 26 : Supported
MCS 27 : Supported
MCS 28 : Supported
MCS 29 : Supported
MCS 30 : Supported
MCS 31 : Supported
802.11n Status:
A-MPDU Tx:
Priority 0 : Enabled
Priority 1 : Enabled
Priority 2 : Enabled
Priority 3 : Enabled
Priority 4 : Enabled
Priority 5 : Enabled
Priority 6 : Disabled
Priority 7 : Disabled
Aggregation scheduler : Enabled
Frame burst : Automatic
Realtime timeout : 10
A-MSDU Tx:
Priority 0 : Enable
Priority 1 : Enable
Priority 2 : Enable
Priority 3 : Enable
Priority 4 : Enable
Priority 5 : Enable
Guard Interval : Any
Rifs Rx : Enabled
802.11ac : Enabled
802.11ac MCS Settings:
MCS 8, Spatial Streams = 1 : Supported
MCS 9, Spatial Streams = 1 : Supported
MCS 8, Spatial Streams = 2 : Supported
MCS 9, Spatial Streams = 2 : Supported
MCS 8, Spatial Streams = 3 : Supported
MCS 9, Spatial Streams = 3 : Supported
MCS 8, Spatial Streams = 4 : Supported
MCS 9, Spatial Streams = 4 : Supported
802.11ax : Enabled
DynamicFrag : Enabled
MultiBssid : Enabled
802.11ax MCS Settings:
MCS 7, Spatial Streams = 1 : Supported
MCS 11, Spatial Streams = 1 : Supported
MCS 7, Spatial Streams = 2 : Supported
MCS 11, Spatial Streams = 2 : Supported
MCS 7, Spatial Streams = 3 : Supported
MCS 11, Spatial Streams = 3 : Supported
MCS 7, Spatial Streams = 4 : Supported
MCS 11, Spatial Streams = 4 : Supported
MCS 7, Spatial Streams = 5 : Supported
MCS 9, Spatial Streams = 5 : Supported
MCS 11, Spatial Streams = 5 : Supported
MCS 7, Spatial Streams = 6 : Supported
MCS 9, Spatial Streams = 6 : Supported
MCS 11, Spatial Streams = 6 : Supported
MCS 7, Spatial Streams = 7 : Supported
MCS 9, Spatial Streams = 7 : Supported
MCS 11, Spatial Streams = 7 : Supported
MCS 7, Spatial Streams = 8 : Supported
MCS 9, Spatial Streams = 8 : Supported
MCS 11, Spatial Streams = 8 : Supported
Beacon Interval : 100
CF Pollable mandatory : Disabled
CF Poll Request Mandatory : Disabled
CFP Period : 4
CFP Maximum Duration : 60
Default Channel : 36
Default Tx Power Level : 1
DTPC Status : Enabled
Fragmentation Threshold : 2346
RSSI Low Check : Disabled
RSSI Threshold : -127 dbm
Pico-Cell-V2 Status : unknown
TI Threshold :
Legacy Tx Beamforming setting : Disabled
Traffic Stream Metrics Status : Disabled
Expedited BW Request Status : Disabled
EDCA profile type check : default-wmm
Call Admision Control (CAC) configuration
Voice AC
Voice AC - Admission control (ACM) : Disabled
Voice Stream-Size : 84000
Voice Max-Streams : 2
Voice Max RF Bandwidth : 75
Voice Reserved Roaming Bandwidth : 6
Voice Load-Based CAC mode : Enabled
Voice tspec inactivity timeout : Enabled
CAC SIP-Voice configuration
SIP based CAC : Disabled
SIP call bandwidth : 64
SIP call bandwith sample-size : 20
Maximum Number of Clients per AP Radio : 200
WLC#show ap dot11 5ghz channel
Leader Automatic Channel Assignment
Channel Assignment Mode : AUTO
Channel Update Interval : 600 seconds
Anchor time (Hour of the day) : 0
Channel Update Contribution
Noise : Enable
Interference : Enable
Load : Disable
Device Aware : Disable
CleanAir Event-driven RRM option : Disabled
Channel Assignment Leader : WLC (192.168.50.240)
Last Run : 108 seconds ago
DCA Sensitivity Level : MEDIUM : 15 dB
DCA 802.11n/ac Channel Width : best
DBS Max Channel Width : 40 MHz
DCA Minimum Energy Limit : -95 dBm
Channel Energy Levels
Minimum : -72 dBm
Average : -72 dBm
Maximum : -72 dBm
Channel Dwell Times
Minimum : 22 minutes 8 seconds
Average : 22 hours 8 minutes 36 seconds
Maximum : 1 day 19 hours 55 minutes 4 seconds
802.11a 5 GHz Auto-RF Channel List
Allowed Channel List : 36,40,44,48,52,56,60,64,100,104,108,112,116,120,124,128,132,136,140,144,149,153,157,161
Unused Channel List : 165
WLC#
各位帮忙看看到底是不是硬件问题呢?
附上控制器的配置
WLC#show running-config
Building configuration...
Current configuration : 17478 bytes
! Last configuration change at 15:49:49 Beijing Thu Apr 9 2020 by admin
! NVRAM config last updated at 15:49:36 Beijing Thu Apr 9 2020 by admin
version 16.12
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform console virtual
hostname WLC
boot-start-marker
boot-end-marker
enable secret 9 $9$eg9z3waYn5RBA.$84Wea9KxI7kZZI/55TgIlLpWf4iXZw52A.gNzjXRXEs
aaa new-model
aaa session-id common
clock timezone Beijing 8 0
clock calendar-valid
vtp mode off
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
no ip domain lookup
login on-success log
subscriber templating
parameter-map type webauth global
virtual-ip ipv4 192.0.2.1
access-session mac-move deny
no device-tracking logging theft
crypto pki server WLC_CA
database archive pkcs12 password 7 08701E1D5D4C53404A525C
issuer-name O=Cisco Virtual Wireless LAN Controller, CN=CA-vWLC_WLC
grant auto
hash sha256
lifetime certificate 3652
lifetime ca-certificate 3652
crypto pki trustpoint TP-self-signed-2141820032
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2141820032
revocation-check none
rsakeypair TP-self-signed-2141820032
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki trustpoint WLC_CA
rsakeypair WLC_CA
crypto pki trustpoint WLC_WLC_TP
enrollment url http://192.168.50.240:80
serial-number
password 7 025756085F535976141759
subject-name O=Cisco Virtual Wireless LAN Controller, CN=WLC_WLC_TP
rsakeypair WLC_WLC_TP
hash sha256
eku request server-auth client-auth
crypto pki certificate chain TP-self-signed-2141820032
certificate self-signed 01
quit
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
quit
crypto pki certificate chain WLC_CA
certificate ca 01
quit
crypto pki certificate chain WLC_WLC_TP
certificate 02
quit
license udi pid C9800-CL-K9 sn 9RBETS4BYBF
service-template webauth-global-inactive
inactivity-timer 3600
service-template DEFAULT_LINKSEC_POLICY_MUST_SECURE
linksec policy must-secure
service-template DEFAULT_LINKSEC_POLICY_SHOULD_SECURE
linksec policy should-secure
service-template DEFAULT_CRITICAL_VOICE_TEMPLATE
voice vlan
service-template DEFAULT_CRITICAL_DATA_TEMPLATE
diagnostic bootup level minimal
memory free low-watermark processor 72681
et-analytics
username admin privilege 15 secret 9 $9$sY6U3Dm/Sk.9x.$SUEubZQdRRDDQp1AP9DZLHqad9Wi4vOZ8W9/WnmT.1Y
redundancy
mode sso
vlan internal allocation policy ascending
vlan 50
class-map match-any AVC-Reanchor-Class
match protocol cisco-jabber-audio
match protocol cisco-jabber-video
match protocol webex-media
match protocol webex-app-sharing
match protocol webex-control
match protocol webex-meeting
match protocol wifi-calling
interface GigabitEthernet1
no switchport
ip address 192.168.80.100 255.255.255.0
shutdown
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet2
switchport trunk native vlan 50
switchport trunk allowed vlan 50
switchport mode trunk
negotiation auto
no mop enabled
no mop sysid
interface Vlan1
no ip address
shutdown
no mop enabled
no mop sysid
interface Vlan50
ip address 192.168.50.240 255.255.255.0
no mop enabled
no mop sysid
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 180 requests 25
ip route 0.0.0.0 0.0.0.0 192.168.50.254
ip ssh version 2
control-plane
line con 0
logging synchronous
stopbits 1
line vty 5 15
wireless aaa policy default-aaa-policy
wireless cts-sxp profile default-sxp-profile
no wireless ipv6 ra wired
wireless management trustpoint WLC_WLC_TP
wireless management interface Vlan50
wireless profile airtime-fairness default-atf-policy 0
wireless profile flex default-flex-profile
description "default flex profile"
wireless profile mesh default-mesh-profile
description "default mesh profile"
wireless profile policy default-policy-profile
description "default policy profile"
vlan VLAN0050
no shutdown
wireless tag site default-site-tag
description "default site tag"
wireless tag policy default-policy-tag
description "default policy-tag"
wlan VOLAN-C9800 policy default-policy-profile
wireless tag rf default-rf-tag
description "default RF tag"
wireless mgmt-via-wireless
wireless fabric control-plane default-control-plane
wlan VOLAN-C9800 1 VOLAN-C9800
security wpa psk set-key ascii 0 1234567890
no security wpa akm dot1x
security wpa akm psk
no shutdown
ap dot11 24ghz rf-profile Low_Client_Density_rf_24gh
coverage data rssi threshold -90
coverage level 2
coverage voice rssi threshold -90
description "pre configured Low Client Density rfprofile for 2.4gh radio"
high-density rx-sop threshold low
tx-power v1 threshold -65
no shutdown
ap dot11 24ghz rf-profile High_Client_Density_rf_24gh
description "pre configured High Client Density rfprofile for 2.4gh radio"
high-density rx-sop threshold medium
rate RATE_11M disable
rate RATE_12M mandatory
rate RATE_1M disable
rate RATE_2M disable
rate RATE_5_5M disable
rate RATE_6M disable
tx-power min 7
no shutdown
ap dot11 24ghz rf-profile Typical_Client_Density_rf_24gh
description "pre configured Typical Client Density rfprofile for 2.4gh radio"
no shutdown
ap dot11 24ghz rate RATE_12M mandatory
ap dot11 24ghz rate RATE_18M disable
ap dot11 24ghz rate RATE_24M disable
ap dot11 24ghz rate RATE_36M disable
ap dot11 24ghz rate RATE_48M disable
ap dot11 24ghz rate RATE_54M disable
ap dot11 24ghz rate RATE_6M disable
ap dot11 5ghz rf-profile Low_Client_Density_rf_5gh
coverage level 2
description "pre configured Low Client Density rfprofile for 5gh radio"
tx-power v1 threshold -60
no shutdown
ap dot11 5ghz rf-profile High_Client_Density_rf_5gh
description "pre configured High Client Density rfprofile for 5gh radio"
rate RATE_9M disable
tx-power min 7
no shutdown
ap dot11 5ghz rf-profile Typical_Client_Density_rf_5gh
description "pre configured Typical Density rfprofile for 5gh radio"
no shutdown
ap dot11 5ghz rate RATE_6M disable
ap country US,CN
ap tag-source-priority 2 source filter
ap tag-source-priority 3 source ap
ap profile default-ap-profile
description "default ap profile"
mgmtuser username hale password 0 wuhao3101561 secret 0 3101561
preferred-mode ipv4
ssh
telnet
end
19 条回复19
wanggang35100
后来是怎么搞好的,我也有一个ap也是没有5G
wanggang35100
这个后来是怎么修改好的,我也是一个ap无5G出来
Cheng_Cao
现在效果出来了吗?
wuhao0015
Mir.cao(Evan) 发表于 2020-7-3 14:58
现在效果出来了吗?
应该是硬件故障,没有继续测试。
martin tang
手上3个AP1815W,一个好像只有5G,另外两个只有2.4G,不知道咋弄,求高人指点
快捷链接
