取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
14
回复
AP-1810W-H-K9反复重启,请问是什么问题?
binwu56007
1、开机后设备引导正常,启动后不断调log,无法连接1815I-ME,大概4分钟左右自动重启。
2、有一台-Z的1810w连接ME正常能自动更新固件,这台-H的不可以,国家代码已填加CN/NZ/US
3、有人说是flash要重新格式化一下,1810w如何格式化?
User AccessVerification
Username:[*03/25/2020 23:59:16.8813] WCP: Opening /tmp/var/platform/board_name failed!
[*03/25/202023:59:16.8813] DOT11_TXP[1]:Domain configured: 51 class:H
[*03/25/202023:59:17.2712] pid 3592's current affinity mask: 3
[*03/25/202023:59:17.2712] pid 3592's new affinity mask: 1
[*03/25/202023:59:17.8610] WCP: Opening /tmp/var/platform/board_name failed!
[*03/25/202023:59:17.8610] DOT11_TXP[0]:Domain configured: 1 class:E
[*03/25/202023:59:18.2509] chpasswd: password for user changed
[*03/25/202023:59:18.3609] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLget_vap_if_index ioctl SIOCGIFINDEX failed for apr1v0 error No such device
[*03/25/202023:59:18.3609] populate_if_index_table: if_index -1 out of range for radio 1vap 0 of 16
[*03/25/202023:59:18.3609] /opt/cisco/bin/wcpd:/san/BUILD/workspace/810MR1_Cheetah_CCO_rebuild/label/corsica/base/../elts-meraki/elements/wcp/wcp_common/wcp_db.cc:3150: void WcpDb::populate_if_index_table(): Assertion `if_index >= 0&& if_index < 64' failed.
[*03/25/202023:59:24.0091] systemd[1]: wcpd.service failed.
[*03/25/202023:59:25.2487] ip6_port srcr2, ip6local fe80::2a2:89ff:fe0e:4120, ip6240e:bc:8b93:4600:2a2:89ff:fe0e:4120, plen 64, gw6 fe80::225:9cff:fe12:ba01,gw6_mac 00:25:9C:12:BA:01, mtu 1500, vid 0, mode6 2(slaac)
[*03/25/202023:59:25.2487] AP IPv6 Address updated from :: to240e:bc:8b93:4600:2a2:89ff:fe0e:4120
[*03/25/202023:59:25.8085] ethernet_port wired0, ip 192.168.100.236, netmask 255.255.255.0,gw 192.168.100.1, mtu 1500, bcast 192.168.100.255, dns1 192.168.100.1, domainCISCO-CAPWAP-CONTROLLER.lan, vid 0, static_ip_failover false,dhcp_vlan_failover false
[*03/25/202023:59:32.7064] root: SSH is enabled by default temporarily in this build
[*03/25/202023:59:33.2162] device aptrace0 entered promiscuous mode
[*03/25/202023:59:33.2662] device to_container entered promiscuous mode
[*03/25/202023:59:40.0341] AP IPv4 Address updated from 0.0.0.0 to 192.168.100.236
[*03/25/202023:59:45.0225] WCP: Opening /tmp/var/platform/board_name failed!
[*03/25/202023:59:45.0225] DOT11_TXP[0]:Domain configured: 1 class:E
[*03/25/202023:59:45.2025] WCP: Opening /tmp/var/platform/board_name failed!
[*03/25/202023:59:45.2025] DOT11_TXP[1]:Domain configured: 51 class:H
[*03/25/202023:59:46.1522] ip6_port srcr2, ip6local fe80::2a2:89ff:fe0e:4120, ip6fd7f:b648:a81c::87f, plen 128, gw6 fe80::225:9cff:fe12:ba01, gw6_mac00:25:9C:12:BA:01, mtu 1500, vid 0, mode6 0(dhcp)
[*03/25/202023:59:46.1522] AP IPv6 Address updated from240e:bc:8b93:4600:2a2:89ff:fe0e:4120 to fd7f:b648:a81c::87f
[*03/25/202023:59:46.5421] DOT11_DRV[1]: Init Radio1
[*03/25/202023:59:46.5421] DOT11_DRV[1]: wifi1: Failed to get radio priv parameter (op4234)
[*03/25/202023:59:46.5621] wifi1 no privateioctls.
[*03/25/202023:59:46.5721] wifi1 no privateioctls.
[*03/25/202023:59:46.5820] wifi1 no privateioctls.
[*03/25/202023:59:46.5820] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4283 arg 1)
[*03/25/202023:59:46.5920] DOT11_DRV[1]: wifi1 acfg cmd 2 failed for wifi1 errno 19(No suchdevice)
[*03/25/202023:59:46.5920] DOT11_DRV[1]: acfg_set_radio_param param 0x200d value 1 failed
[*03/25/202023:59:46.6020] DOT11_DRV[1]: wifi1 acfg cmd 2 failed for wifi1 errno 19(No suchdevice)
[*03/25/202023:59:46.6020] DOT11_DRV[1]: acfg_set_radio_param param 0x2017 value 1 failed
[*03/25/202023:59:46.6020] DOT11_DRV[1]: wifi1 acfg cmd 19 failed for wifi1 errno 19(Nosuch device)
[*03/25/202023:59:46.6020] DOT11_DRV[1]: Radio 1 NF_Calibration request failed !
[*03/25/202023:59:46.6120] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4176 arg 1)
[*03/25/202023:59:46.6120] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4235 arg 1)
[*03/25/202023:59:46.6220] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4432 arg 2651)
[*03/25/202023:59:46.6220] DOT11_DRV[1]: wifi1 acfg cmd 16 failed for wifi1 errno 19(Nosuch device)
[*03/25/202023:59:46.6320] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v0 error No such device
[*03/25/202023:59:46.6320] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:2F
[*03/25/202023:59:46.6320] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v1 error No such device
[*03/25/202023:59:46.6320] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:2E
[*03/25/202023:59:46.6420] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v2 error No such device
[*03/25/202023:59:46.6420] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:2D
[*03/25/202023:59:46.6420] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v3 error No such device
[*03/25/202023:59:46.6420] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:2C
[*03/25/202023:59:46.6520] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v4 error No such device
[*03/25/202023:59:46.6520] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:2B
[*03/25/202023:59:46.6620] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v5 error No such device
[*03/25/202023:59:46.6620] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:2A
[*03/25/202023:59:46.6620] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v6 error No such device
[*03/25/202023:59:46.6620] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:29
[*03/25/202023:59:46.6720] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v7 error No such device
[*03/25/202023:59:46.6720] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:28
[*03/25/202023:59:46.6820] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v8 error No such device
[*03/25/202023:59:46.6820] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:27
[*03/25/202023:59:46.6920] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v9 error No such device
[*03/25/202023:59:46.6920] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:26
[*03/25/202023:59:46.6920] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v10 error No such device
[*03/25/202023:59:46.6920] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:25
[*03/25/202023:59:46.7020] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v11 error No such device
[*03/25/202023:59:46.7020] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:24
[*03/25/202023:59:46.7020] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v12 error No such device
[*03/25/202023:59:46.7020] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:23
[*03/25/202023:59:46.7120] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v13 error No such device
[*03/25/202023:59:46.7120] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:22
[*03/25/202023:59:46.7220] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v14 error No such device
[*03/25/202023:59:46.7220] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:21
[*03/25/202023:59:46.7220] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v15 error No such device
[*03/25/202023:59:46.7220] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 doesnot match with driver BSSID Addr: 00:A2:89:0F:6C:20
[*03/25/202023:59:46.7220] DOT11_DRV[1]: Stop Radio1 - Begin
[*03/25/202023:59:46.7320] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_stop_radio ioctl SIOCGIFFLAGS failed for wifi1 error -1
[*03/25/202023:59:46.7320] DOT11_DRV[1]: Failure to Stop radio during Base DriverInitialization
[*03/25/202023:59:46.7320] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v0 error No such device
[*03/25/202023:59:46.7420] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v1 error No such device
[*03/25/202023:59:46.7420] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v2 error No such device
[*03/25/202023:59:46.7520] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v3 error No such device
[*03/25/202023:59:46.7520] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v4 error No such device
[*03/25/202023:59:46.7620] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v5 error No such device
[*03/25/202023:59:46.7720] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v6 error No such device
[*03/25/202023:59:46.7720] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v7 error No such device
[*03/25/202023:59:46.7820] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v8 error No such device
[*03/25/202023:59:46.7820] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v9 error No such device
[*03/25/202023:59:46.7920] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v10 error No such device
[*03/25/202023:59:46.7920] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v11 error No such device
[*03/25/202023:59:46.8020] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v12 error No such device
[*03/25/202023:59:46.8020] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v13 error No such device
[*03/25/202023:59:46.8120] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v14 error No such device
[*03/25/202023:59:46.8120] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v15 error No such device
[*03/25/202023:59:46.8220] DOT11_DRV[1]: mon1 ioctlop=0x8bf2 len=4 failed: 19 (No such device)
[*03/25/202023:59:46.8220] DOT11_DRV[1]: set mode_str 11A to mon1 failed
[*03/25/202023:59:46.8220] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v0 error No such device
[*03/25/202023:59:46.8320] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v1 error No such device
[*03/25/202023:59:46.8420] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v2 error No such device
[*03/25/202023:59:46.8420] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v3 error No such device
[*03/25/202023:59:46.8520] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v4 error No such device
[*03/25/202023:59:46.8520] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v5 error No such device
[*03/25/202023:59:46.8620] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v6 error No such device
[*03/25/202023:59:46.8720] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v7 error No such device
[*03/25/202023:59:46.8720] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v8 error No such device
[*03/25/202023:59:46.8820] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v9 error No such device
[*03/25/202023:59:46.8820] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v10 error No such device
[*03/25/202023:59:46.8920] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v11 error No such device
[*03/25/202023:59:46.8920] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v12 error No such device
[*03/25/202023:59:46.9019] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v13 error No such device
[*03/25/202023:59:46.9019] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v14 error No such device
[*03/25/202023:59:46.9119] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTL is_vap_presentioctl SIOCGIFFLAGS failed for apr1v15 error No such device
[*03/25/202023:59:46.9219] DOT11_DRV[1]: set_channel Channel set to 36
[*03/25/202023:59:46.9219] DOT11_DRV[1]: wifi1 acfg cmd 17 failed for wifi1 errno 19(Nosuch device)
[*03/25/202023:59:46.9319] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4242 arg 0)
[*03/25/202023:59:46.9319] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4241 arg 0)
[*03/25/202023:59:46.9319] WCP: Opening /click/cwx1/radio_stats/vap_chan_util_stats_supportfailed!
[*03/25/202023:59:46.9419] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v0 error No such device
[*03/25/202023:59:46.9419] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v1 error No such device
[*03/25/202023:59:46.9719] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v2 error No such device
[*03/25/202023:59:46.9719] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v3 error No such device
[*03/25/202023:59:46.9819] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v4 error No such device
[*03/25/202023:59:46.9819] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v5 error No such device
[*03/25/202023:59:46.9919] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v6 error No such device
[*03/25/202023:59:46.9919] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v7 error No such device
[*03/25/202023:59:47.0019] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v8 error No such device
[*03/25/202023:59:47.0019] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v9 error No such device
[*03/25/202023:59:47.0119] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v10 error No such device
[*03/25/202023:59:47.0119] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v11 error No such device
[*03/25/202023:59:47.0319] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v12 error No such device
[*03/25/202023:59:47.0319] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v13 error No such device
[*03/25/202023:59:47.0419] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v14 error No such device
[*03/25/202023:59:47.0419] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLvendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v15 error No such device
[*03/26/202000:00:07.6655] WCP: Opening /tmp/var/platform/board_name failed!
[*03/26/202000:00:07.6655] DOT11_TXP[0]:Domain configured: 51 class:H
[*03/26/202000:00:08.6851] WCP: Opening /tmp/var/platform/board_name failed!
[*03/26/202000:00:08.6851] DOT11_TXP[0]:Domain configured: 1 class:E
[*03/26/202000:00:09.2150] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11AthDriverIOCTLget_vap_if_index ioctl SIOCGIFINDEX failed for apr1v0 error No such device
[*03/26/202000:00:09.2150] populate_if_index_table: if_index -1 out of range for radio 1vap 0 of 16
[*03/26/202000:00:09.2150] /opt/cisco/bin/wcpd:/san/BUILD/workspace/810MR1_Cheetah_CCO_rebuild/label/corsica/base/../elts-meraki/elements/wcp/wcp_common/wcp_db.cc:3150: void WcpDb::populate_if_index_table(): Assertion `if_index >= 0&& if_index < 64' failed.
14 条回复14
binwu56007
AP00A2.890E.4120#sho ver
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
Cisco AP Software, (ap1g4), C1810, RELEASE SOFTWARE
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Fri Jan 31 20:35:00 PST 2020
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version 37
AP00A2.890E.4120 uptime is 0 days, 0 hours, 1 minutes
Last reload time : Thu Mar 26 00:17:48 UTC 2020
Last reload reason : Systemd critical process crash
cisco AIR-AP1810W-H-K9 ARMv7 Processor rev 0 (v7l) with 476448/240480K bytes of memory.
Processor board ID KWC20310052
AP Running Image : 8.10.112.0
Primary Boot Image : 8.10.112.0
Backup Boot Image : 8.5.161.0
Primary Boot Image Hash:
Backup Boot Image Hash:
4 Gigabit Ethernet interfaces
1 802.11 Radios
Radio FW version : 64035bf3490c0cb9e24ce9b09a56fe6c
NSS FW version : NSS.AK.C.CS-3-fix3
Base ethernet MAC Address : 00:A2:89:0E:41:20
Part Number : 0-0000-00
PCA Assembly Number : 074-104133-01
PCA Revision Number : 01
PCB Serial Number : KWC20310052
Top Assembly Part Number : 000-00000-00
Top Assembly Serial Number : KWC20310052
Top Revision Number : A0
Product/Model Number : AIR-AP1810W-H-K9
binwu56007
(Cisco Controller) >*spamApTask0: Apr 24 18:51:21.501: 00:a2:89:0f:6c:20 Discovery Request from 192.168.100.236:5272
*spamApTask0: Apr 24 18:51:21.501: 00:a2:89:0f:6c:20 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50, MaxLicense=50 joined Aps =2
*spamApTask0: Apr 24 18:51:21.501: 00:a2:89:0f:6c:20 apType = 98 apModel:
spamApTask0: Apr 24 18:52:32.835: 00:a2:89:0f:6c:20 Discovery Request from 192.168.100.236:5272
*spamApTask0: Apr 24 18:52:32.836: 00:a2:89:0f:6c:20 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50, MaxLicense=50 joined Aps =2
*spamApTask0: Apr 24 18:52:32.836: 00:a2:89:0f:6c:20 apType = 98 apModel:
*spamApTask0: Apr 24 18:52:32.836: 00:a2:89:0f:6c:20 Discovery Response sent to 192.168.100.236:5272
*osapiBsnTimer: Apr 24 18:52:35.501: Gateway is not reachable - Couldn't complete Gateway check
*spamApTask0: Apr 24 18:52:42.347: 00:a2:89:0f:6c:20 Discovery Request from 192.168.100.236:5272
*spamApTask0: Apr 24 18:52:42.347: 00:a2:89:0f:6c:20 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50, MaxLicense=50 joined Aps =2
*spamApTask0: Apr 24 18:52:42.347: 00:a2:89:0f:6c:20 apType = 98 apModel:
HalbertLei75806
我也遇到同样的问题 尝试升级固件到最新后发生的
看样子是ME WLC收到了AP1810W的 Discovery Request了。但是没有回response呢。
有debug看过吗。
另外,AP1810W可以试试恢复出厂设置
Using the Mode Button
Using the Mode button (see Figure 3) you can:
  • Reset the AP to it’s default factory-shipped configuration.
  • Clear the AP’s internal storage, including all configuration files and the regulatory domain configuration.
To use the mode button, press, and keep pressed, the mode button on the access point during the AP's boot cycle. Wait until the AP's status LED changes to Amber. During this, the AP console shows a seconds counter, counting the number of seconds the mode button is pressed. Then:
  • To reset the AP to it’s default factory-shipped configuration, keep the mode button pressed for less than 20 seconds. The AP's configuration files are cleared.
This resets all configuration settings to factory defaults, including passwords, WEP keys, the IP address, and the SSID. However, the regulatory domain provisioning is not reset.
  • To clear the AP’s internal storage, including all configuration files and the regulatory domain configuration, keep the mode button pressed for more than 20 seconds, but less than 60 seconds.
The AP's status LED changes from Amber to Red, and all the files in the AP's storage directory are cleared. This also removes any regulatory domain provisioning made previously and resets the AP back to -UX domain.
If you keep the mode button pressed for more than 60 seconds, the mode button is assumed faulty and no changes are made.
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
binwu56007
有debug看过吗。
另外,AP ...
1810w用不同的固件反应不一样,刷8.10.121后直接不给机会登录,不停的跳log然后反复重启,根本进不到enable模式下。
8.5.150.的固件提示:
debug提示
[*04/01/202007:17:00.9779] CAPWAP State: Discovery
[*04/01/202007:17:00.9779] Discovery failed 5 times. Release/Renew DHCP
[*04/01/202007:17:00.9779] Did not get log server settings from DHCP.
[*04/01/202007:17:00.9779] IP DNS query forCISCO-CAPWAP-CONTROLLER.CISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:00.9879] Could Not resolveCISCO-CAPWAP-CONTROLLER.CISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:00.9879] Discovery Request sent to 255.255.255.255, discovery typeUNKNOWN(0)
[*04/01/202007:17:00.9879] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*04/01/202007:17:00.9879] Discovery Response from 192.168.100.2
[*04/01/202007:17:00.9879] This AP model is supported by controller version newer than8.2.102.2!
[*04/01/202007:17:00.9879] Discovery response from MWAR ''running version 0.0.0.0 isrejected.
[*04/01/202007:17:00.9879] Failed to decode discovery response(status = 4).
[*04/01/202007:17:00.9879] CAPWAP SM handler: Failed to process message type 2 state 2.
[*04/01/202007:17:00.9879] Failed to handle capwap control message from controller - status4
[*04/01/202007:17:00.9879] Failed to process unencrypted capwap packet 0x2042000 from192.168.100.2
[*04/01/202007:17:00.9879] Failed to send message to CAPWAP state machine, msgId 0
[*04/01/202007:17:00.9879] Failed to send capwap message 0 to the state machine. Packetalready freed.
[*04/01/202007:17:00.9879] IPv4 wtpProcessPacketFromSocket returned 4
[*04/01/202007:17:02.9073]
[*04/01/202007:17:02.9073] !!!!! {watchdogd} Process wcpd gone for 420s
[*04/01/202007:17:10.4749] Could not discover any WLC.
[*04/01/202007:17:10.4749] IP DNS 192.168.100.1, 0.0.0.0; DomainCISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:10.4849] IPv6 DNS fd7f:b648:a81c::1, ::; Domain
[*04/01/202007:17:10.4849] WTP IP address changed from 0.0.0.0 to 192.168.100.232, restartCAPWAP.
[*04/01/202007:17:10.4849] Lost connection to the controller, going to restart CAPWAP(reason : WTP IP address changed)...
[*04/01/202007:17:10.4849] Restarting CAPWAP State Machine.
[*04/01/202007:17:10.5849] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state:Discovery(2).
[*04/01/202007:17:10.5849] dtls_connection_find_using_link_info: Searching connection[192.168.100.232]:5248--[::]:5246, result (nil)
[*04/01/202007:17:10.5849] dtls_connection_find_using_link_info: Searching connection[192.168.100.232]:5248--[::]:5247, result (nil)
[*04/01/202007:17:10.5849] CAPWAP State: DTLS Teardown
[*04/01/202007:17:10.6049] [DP] Deleting capwap datapath
[*04/01/202007:17:10.6049] CAPWAP data tunnel delete from forwarding succeeded
[*04/01/202007:17:15.2234] DTLS session cleanup completed. Restarting capwap state machine.
[*04/01/202007:17:15.2234] Restarting WLC Discovery
[*04/01/202007:17:15.2234] Starting Discovery.
[*04/01/202007:17:15.2334] IP DNS 192.168.100.1, 0.0.0.0; DomainCISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:15.2334] IPv6 DNS fd7f:b648:a81c::1, ::; Domain
[*04/01/202007:17:15.2334] CAPWAP State: Discovery
[*04/01/202007:17:15.2334] Did not get log server settings from DHCP.
[*04/01/202007:17:15.2334] IP DNS query forCISCO-CAPWAP-CONTROLLER.CISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:15.2434] Could Not resolveCISCO-CAPWAP-CONTROLLER.CISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:15.2434] Discovery Request sent to 255.255.255.255, discovery typeUNKNOWN(0)
[*04/01/202007:17:15.2434] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*04/01/202007:17:15.2534] Discovery Response from 192.168.100.2
[*04/01/202007:17:15.2534] This AP model is supported by controller version newer than8.2.102.2!
[*04/01/202007:17:15.2534] Discovery response from MWAR ''running version 0.0.0.0 isrejected.
[*04/01/202007:17:15.2534] Failed to decode discovery response(status = 4).
[*04/01/202007:17:15.2534] CAPWAP SM handler: Failed to process message type 2 state 2.
[*04/01/202007:17:15.2534] Failed to handle capwap control message from controller - status4
[*04/01/202007:17:15.2534] Failed to process unencrypted capwap packet 0x203e000 from192.168.100.2
[*04/01/202007:17:15.2534] Failed to send message to CAPWAP state machine, msgId 0
[*04/01/202007:17:15.2534] Failed to send capwap message 0 to the state machine. Packetalready freed.
[*04/01/202007:17:15.2534] IPv4 wtpProcessPacketFromSocket returned 4
[*04/01/202007:17:24.7404] Could not discover any WLC.
[*04/01/202007:17:24.7404] IP DNS 192.168.100.1, 0.0.0.0; DomainCISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:24.7504] IPv6 DNS fd7f:b648:a81c::1, ::; Domain
[*04/01/202007:17:24.7504] Starting Discovery.
[*04/01/202007:17:24.7504] IP DNS 192.168.100.1, 0.0.0.0; DomainCISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:24.7504] CAPWAP State: Discovery
[*04/01/202007:17:24.7504] Did not get log server settings from DHCP.
[*04/01/202007:17:24.7504] IP DNS query forCISCO-CAPWAP-CONTROLLER.CISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:24.7604] Could Not resolveCISCO-CAPWAP-CONTROLLER.CISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:24.7604] Discovery Request sent to 255.255.255.255, discovery typeUNKNOWN(0)
[*04/01/202007:17:24.7604] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*04/01/202007:17:24.7604] Discovery Response from 192.168.100.2
[*04/01/202007:17:24.7604] This AP model is supported by controller version newer than8.2.102.2!
[*04/01/202007:17:24.7604] Discovery response from MWAR ''running version 0.0.0.0 isrejected.
[*04/01/202007:17:24.7604] Failed to decode discovery response(status = 4).
[*04/01/202007:17:24.7604] CAPWAP SM handler: Failed to process message type 2 state 2.
[*04/01/202007:17:24.7604] Failed to handle capwap control message from controller - status4
[*04/01/202007:17:24.7604] Failed to process unencrypted capwap packet 0x2040000 from192.168.100.2
[*04/01/202007:17:24.7604] Failed to send message to CAPWAP state machine, msgId 0
[*04/01/202007:17:24.7604] Failed to send capwap message 0 to the state machine. Packetalready freed.
[*04/01/202007:17:24.7604] IPv4 wtpProcessPacketFromSocket returned 4
[*04/01/202007:17:34.2475] Could not discover any WLC.
[*04/01/202007:17:34.2475] IP DNS 192.168.100.1, 0.0.0.0; DomainCISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:34.2475] IPv6 DNS fd7f:b648:a81c::1, ::; Domain
[*04/01/202007:17:34.2475] Starting Discovery.
[*04/01/202007:17:34.2575] IP DNS 192.168.100.1, 0.0.0.0; DomainCISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:34.2575] IPv6 DNS fd7f:b648:a81c::1, ::; Domain
[*04/01/202007:17:34.2575] CAPWAP State: Discovery
[*04/01/202007:17:34.2575] Did not get log server settings from DHCP.
[*04/01/202007:17:34.2575] IP DNS query forCISCO-CAPWAP-CONTROLLER.CISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:34.2775] Could Not resolveCISCO-CAPWAP-CONTROLLER.CISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:34.2775] Discovery Request sent to 255.255.255.255, discovery typeUNKNOWN(0)
[*04/01/202007:17:34.2775] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*04/01/202007:17:34.2775] Discovery Response from 192.168.100.2
[*04/01/202007:17:34.2775] This AP model is supported by controller version newer than8.2.102.2!
[*04/01/202007:17:34.2775] Discovery response from MWAR ''running version 0.0.0.0 isrejected.
[*04/01/202007:17:34.2775] Failed to decode discovery response(status = 4).
[*04/01/202007:17:34.2775] CAPWAP SM handler: Failed to process message type 2 state 2.
[*04/01/202007:17:34.2775] Failed to handle capwap control message from controller - status4
[*04/01/202007:17:34.2775] Failed to process unencrypted capwap packet 0x2042000 from192.168.100.2
[*04/01/202007:17:34.2775] Failed to send message to CAPWAP state machine, msgId 0
[*04/01/202007:17:34.2775] Failed to send capwap message 0 to the state machine. Packetalready freed.
[*04/01/202007:17:34.2775] IPv4 wtpProcessPacketFromSocket returned 4
[*04/01/202007:17:43.7545] Could not discover any WLC.
[*04/01/202007:17:43.7545] IP DNS 192.168.100.1, 0.0.0.0; DomainCISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:43.7545] IPv6 DNS fd7f:b648:a81c::1, ::; Domain
[*04/01/202007:17:43.7545] Starting Discovery.
[*04/01/202007:17:43.7545] CAPWAP State: Discovery
[*04/01/202007:17:43.7645] Did not get log server settings from DHCP.
[*04/01/202007:17:43.7645] IP DNS query forCISCO-CAPWAP-CONTROLLER.CISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:43.7845] Could Not resolveCISCO-CAPWAP-CONTROLLER.CISCO-CAPWAP-CONTROLLER.lan
[*04/01/202007:17:43.7845] Discovery Request sent to 255.255.255.255, discovery typeUNKNOWN(0)
[*04/01/202007:17:43.7845] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*04/01/202007:17:43.7845] AP in local mode switch to standalone
[*04/01/202007:17:43.7845] Discovery Response from 192.168.100.2
[*04/01/202007:17:43.7845] This AP model is supported by controller version newer than8.2.102.2!
[*04/01/202007:17:43.7845] Discovery response from MWAR ''running version 0.0.0.0 isrejected.
[*04/01/202007:17:43.7845] Failed to decode discovery response(status = 4).
[*04/01/202007:17:43.7845] CAPWAP SM handler: Failed to process message type 2 state 2.
[*04/01/202007:17:43.7845] Failed to handle capwap control message from controller - status4
[*04/01/202007:17:43.7845] Failed to process unencrypted capwap packet 0x203e000 from192.168.100.2
[*04/01/202007:17:43.7845] Failed to send message to CAPWAP state machine, msgId 0
[*04/01/202007:17:43.7845] Failed to send capwap message 0 to the state machine. Packetalready freed.
[*04/01/202007:17:43.7845] IPv4 wtpProcessPacketFromSocket returned 4
binwu56007 发表于 2020-4-26 19:24
1810w用不同的固件反应不一样,刷8.10.121后直接不给机会登录,不停的跳log然后反复重启,根本进不到enab ...
8.5这个貌似有点像Bug,最近这个问题貌似比较多啊。还不知道咋解决。多换两个版本试试呢?8.5.161情况有什么不同吗
binwu56007
1540488497lcj 发表于 2020-4-27 15:53
8.5这个貌似有点像Bug,最近这个问题貌似比较多啊。还不知道咋解决。多换两个版本试试呢?8.5.161情况有 ...
现在用过的版本是8.5.150/8.5.161/8.10.112/8.10.120都这昂,前面8.5的版本还给你进CLI的机会,后面直接不给你CLI的机会哈哈哈
另外ap有没有可能被特殊设定过(类似加密或者受控版本),不允许再接其他的AC了
YilinChen
查查兼容性例表,AC和AP上的版本需要适配在兼容性例表里
18653465190
这种重复RESET的情况一般都是设备的IOS导致的。
iliaodong
我的1810W也遇到了同样的故障,就是不让你加入,兼容性已经检查过了。
binwu56007
[*03/31/2020 14:59:03.3955] CAPWAP State: DTLS Teardown
[*03/31/2020 14:59:03.4155] [DP] Deleting capwap datapath
[*03/31/2020 14:59:03.4155] CAPWAP data tunnel delete from forwarding succeeded
[*03/31/2020 14:59:08.0441] DTLS session cleanup completed. Restarting capwap state machine.
[*03/31/2020 14:59:08.0441] Restarting WLC Discovery
[*03/31/2020 14:59:08.0441] Starting Discovery.
[*03/31/2020 14:59:08.0441] IP DNS 192.168.100.1, 0.0.0.0; Domain
[*03/31/2020 14:59:08.0541] IPv6 DNS fd7f:b648:a81c::1, ::; Domain
[*03/31/2020 14:59:08.0541] CAPWAP State: Discovery
[*03/31/2020 14:59:08.0541] Did not get log server settings from DHCP.
[*03/31/2020 14:59:08.0541] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*03/31/2020 14:59:08.0541] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*03/31/2020 14:59:08.0541] Discovery Response from 192.168.100.2
[*03/31/2020 14:59:08.0541] This AP model is supported by controller version newer than 8.2.102.2!
[*03/31/2020 14:59:08.0541] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*03/31/2020 14:59:08.0541] Failed to decode discovery response(status = 4).
[*03/31/2020 14:59:08.0541] CAPWAP SM handler: Failed to process message type 2 state 2.
[*03/31/2020 14:59:08.0541] Failed to handle capwap control message from controller - status 4
[*03/31/2020 14:59:08.0541] Failed to process unencrypted capwap packet 0x22b8000 from 192.168.100.2
[*03/31/2020 14:59:08.0541] Failed to send message to CAPWAP state machine, msgId 0
[*03/31/2020 14:59:08.0541] Failed to send capwap message 0 to the state machine. Packet already freed.
[*03/31/2020 14:59:08.0541] IPv4 wtpProcessPacketFromSocket returned 4
[*03/31/2020 14:59:17.5611] Could not discover any WLC.
[*03/31/2020 14:59:17.5611] IP DNS 192.168.100.1, 0.0.0.0; Domain
[*03/31/2020 14:59:17.5611] IPv6 DNS fd7f:b648:a81c::1, ::; Domain
[*03/31/2020 14:59:17.5611] Starting Discovery.
[*03/31/2020 14:59:17.5611] CAPWAP State: Discovery
[*03/31/2020 14:59:17.5611] Did not get log server settings from DHCP.
[*03/31/2020 14:59:17.5711] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*03/31/2020 14:59:17.5711] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*03/31/2020 14:59:17.5711] Discovery Response from 192.168.100.2
[*03/31/2020 14:59:17.5711] This AP model is supported by controller version newer than 8.2.102.2!
[*03/31/2020 14:59:17.5711] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*03/31/2020 14:59:17.5711] Failed to decode discovery response(status = 4).
[*03/31/2020 14:59:17.5711] CAPWAP SM handler: Failed to process message type 2 state 2.
[*03/31/2020 14:59:17.5711] Failed to handle capwap control message from controller - status 4
[*03/31/2020 14:59:17.5711] Failed to process unencrypted capwap packet 0x22ba000 from 192.168.100.2
[*03/31/2020 14:59:17.5711] Failed to send message to CAPWAP state machine, msgId 0
[*03/31/2020 14:59:17.5711] Failed to send capwap message 0 to the state machine. Packet already freed.
[*03/31/2020 14:59:17.5711] IPv4 wtpProcessPacketFromSocket returned 4
[*03/31/2020 14:59:27.0681] Could not discover any WLC.
[*03/31/2020 14:59:27.0681] IP DNS 192.168.100.1, 0.0.0.0; Domain
[*03/31/2020 14:59:27.0681] IPv6 DNS fd7f:b648:a81c::1, ::; Domain
[*03/31/2020 14:59:27.0681] Starting Discovery.
[*03/31/2020 14:59:27.0681] CAPWAP State: Discovery
[*03/31/2020 14:59:27.0681] Did not get log server settings from DHCP.
[*03/31/2020 14:59:27.0681] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*03/31/2020 14:59:27.0781] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*03/31/2020 14:59:27.0781] Discovery Response from 192.168.100.2
[*03/31/2020 14:59:27.0781] This AP model is supported by controller version newer than 8.2.102.2!
[*03/31/2020 14:59:27.0781] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*03/31/2020 14:59:27.0781] Failed to decode discovery response(status = 4).
[*03/31/2020 14:59:27.0781] CAPWAP SM handler: Failed to process message type 2 state 2.
[*03/31/2020 14:59:27.0781] Failed to handle capwap control message from controller - status 4
[*03/31/2020 14:59:27.0781] Failed to process unencrypted capwap packet 0x22bc000 from 192.168.100.2
[*03/31/2020 14:59:27.0781] Failed to send message to CAPWAP state machine, msgId 0
[*03/31/2020 14:59:27.0781] Failed to send capwap message 0 to the state machine. Packet already freed.
[*03/31/2020 14:59:27.0781] IPv4 wtpProcessPacketFromSocket returned 4
[*03/31/2020 14:59:36.5752] Could not discover any WLC.
[*03/31/2020 14:59:36.5752] IP DNS 192.168.100.1, 0.0.0.0; Domain
[*03/31/2020 14:59:36.5752] IPv6 DNS fd7f:b648:a81c::1, ::; Domain
[*03/31/2020 14:59:36.5752] Starting Discovery.
[*03/31/2020 14:59:36.5752] CAPWAP State: Discovery
[*03/31/2020 14:59:36.5752] Did not get log server settings from DHCP.
[*03/31/2020 14:59:36.5752] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*03/31/2020 14:59:36.5752] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*03/31/2020 14:59:36.5852] AP in local mode switch to standalone
[*03/31/2020 14:59:36.5852] Discovery Response from 192.168.100.2
[*03/31/2020 14:59:36.5852] This AP model is supported by controller version newer than 8.2.102.2!
[*03/31/2020 14:59:36.5852] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*03/31/2020 14:59:36.5852] Failed to decode discovery response(status = 4).
就是联系不上ME能ping通,可以从路由器上获得DHCP地址,当前me版本8.10.120/AP8.5.161,手动将AP刷成8.10.121,也不行。
binwu56007
Number of APs.................................... 3
Global AP User Name.............................. admin
Global AP Dot1x User Name........................ Not Configured
Global AP Dot1x EAP Method....................... EAP-FAST
* prefix indicates Cisco Internal AP
AP Name Slots AP Model Ethernet MAC Location Country IP Address Clients DSE Location
*AP1880.9025.6A38 2 AIR-AP1815I-Z-K9 18:80:90:25:6a:38 default location NZ 192.168.100.225 0 [0 ,0 ,0 ]
AP0042.5AB4.1830 3 AIR-AP1810W-Z-K9 00:42:5a:b4:18:30 default location NZ 192.168.100.244 0 [0 ,0 ,0 ]
APC4F7.D58D.CDA8 3 AIR-AP1815W-H-K c4:f7:d5:8d:cd:a8 default location 192.168.100.248 0 [0 ,0 ,0 ]
加上了一台1815W-H的直接就可以连上,可以正常使用.......手头这条两台1810W-H无解了。
wuhao0015
前几天我的1810W-H也遇到了,我觉得应该是硬件问题,楼主解决了吗???
RMA解决问题
快捷链接
