还是不认
APD0EC.356A.02E0>en
Password:
% Invalid input detected at '^' marker.
APD0EC.356A.02E0#config t
APD0EC.356A.02E0#debug capwap console cli
% Invalid input deteeted at '^' marker.
APD0EC.356A.02E0#
抱歉,AP1852和IOS AP不一样,应该不支持debug capwap console cli命令。您是想进去配置IP地址的吗?如果是的话,请使用 cawap ap ip address 等命令:
AP#capwap ap ip <IP-address> <subnet mask> <default-gateway> [<dns1-ip-address> <dns2-ip-address> <domain>]
AP#capwap ap primary-base <WLC-sys-name> <IP-address>
AP#capwap ap hostname <name>
也是不认,搞不懂啥原因
User Access Verification
Username: [*06/04/2021 13:58:39.5786] DOT11_DRV[0]: Channel set to 11, width 20
[*06/04/2021 13:58:39.5786] DOT11_DRV[0]: Stop Radio0
[*06/04/2021 13:58:39.6186] DOT11_DRV[0]: set_channel Channel set to 11
[*06/04/2021 13:58:39.6186] DOT11_DRV[0]: Start Radio0
Username: admin
Password:
APD0EC.356A.02E0>en
Password:
APD0EC.356A.02E0#cawap ap ip 192.168.106.124 255.255.255.0
APD0EC.356A.02E0#
您的命令输错了:APD0EC.356A.02E0#cawap ap ip 192.168.106.124 255.255.255.0 <-------------不是cawap,是capwap
我把AP重置了,然后按这个设置192.168.106.166的管理IP,Router IP 192.168.106.254,save,保存了,
路由器重启后访问不起作用192.168.106.166,设置的无线SSID:MX2021也没有出现,一直跳下面的内容
Username: a[*06/04/2021 17:07:24.2502] Waiting for preferred uplink IP configura
tion
[*06/04/2021 17:07:29.2687] Waiting for preferred uplink IP configuration
[*06/04/2021 17:07:30.2783] Resetting wired0 and restart DHCP client
[*06/04/2021 17:07:36.4264] Waiting for preferred uplink IP configuration
[*06/04/2021 17:07:41.4349] Waiting for preferred uplink IP configuration
[*06/04/2021 17:07:46.4533] Waiting for preferred uplink IP configuration
[*06/04/2021 17:07:47.4730] Resetting wired0 and restart DHCP client
