取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
9
回复
WLC 2504升级导致无法重启 !!!凌晨四点半在线等 急!急!急
13817778909
大家有升级2504碰到过类似的问题嘛!
1、从7.0.220.0升到7.6.120.0,提示升级成功后reboot,用7.6.120.0的IOS进入系统,系统一直停在(启动镜像)这个阶段,无法启动,如下。
WLCNG Boot Loader Version 1.0.16 (Built on Feb 28 2011 at 13:14:54 by cisco)
Board Revision 0.0 (SN: PSZ16440A3A, Type: AIR-CT2504-K9) (W)
Verifying boot loader integrity... OK.
OCTEON CN5230C-SCP pass 2.0, Core clock: 750 MHz, DDR clock: 330 MHz (660 Mhz data rate)
CPU Cores: 4
DRAM: 1024 MB
Flash: 32 MB
Clearing DRAM........ done
Network: octeth0', octeth1, octeth2, octeth3
' - Active interface
E - Environment MAC address override
CF Bus 0 (IDE): OK
IDE device 0:
- Model: 1GB CompactFlash Card Firm: CF B612J Ser#: A191105254A12j5C7VDr
- Type: Hard Disk
- Capacity: 977.4 MB = 0.9 GB (2001888 x 512)
Press now to access the Boot Menu...
Loading primary image (7.6.130.0)
100%
36933676 bytes read
Launching...
Launching images...
后来以为7.6.120.0IOS校验有问题,就把backup的IOS也升到了7.6.130.0,结果也是到了启动镜像这里死机,悲剧的是active和
backup镜像都是7.6,两个全部启动不了。都死在这个lauching images。后来就重启按ESC进入boot menu,选择了数字6.
Boot Loader Menu
1. Run primary image (7.6.130.0) - Active
2. Run backup image (Bad image type)
3. Change active boot image
4. Clear configuration
5. Format FLASH Drive
6. Manually update images
Enter selection: 6
Launching...
Launching images...
init started: BusyBox v1.6.0 (2010-05-13 17:50:10 EDT) multi-call binary
Mount failed for selinuxfs on /selinux: No such file or directory
starting pid 655, tty '': '/etc/init.d/rcS'
Use DHCP for ip configuration (Y/n)? n
Enter switch IP address: 10.40.3.2
Enter switch netmask: 255.255.255.0
Enter switch gateway: 10.40.3.1
Enter TFTP server IP address: 10.40.3.3
You have entered:
IP Address : 10.40.3.2
Netmask : 255.255.255.0
Gateway : 10.40.3.1
Server Ip Addr : 10.40.3.3
Is this correct(y/N)? y
!!! WARNING updating using .aes or unapproved files will disable this unit !!!
Do you want to update RTOS (y/N)? y
Do you want to update Primary Or Secondary Image (P/s)? s
Enter filename for RTOS update: AIR-CT2500-K9-7-6-130-0.aes
Enter filename for FP update:
不知道这里的RTOS和FP是什么文件,就直接用了7.6.130.0的镜像试试能不能手工恢复,但是最后升级没成功,导致backup的IOS镜像是bad file type。
有实际操作过的兄弟过,在线等 ,非常 感谢了。如果有遇到的兄弟麻烦加下我的QQ26296016(方也)。在此感谢了。
1 个已接受解答
已接受的解答
yanzha4
RTOS文件啥的 你找TAC开case吧,可以帮你恢复。
在原帖中查看解决方案
9 条回复9
yanzha4
13nash
Level 8
Level 8
最后解决了么
suzhouxiaoniu
真的没遇到过,能不能开个CASE
sxczwxf
我也遇到同样的问题
zhangjixiang
我之前也遇到过一次升级完成后重启,设备一直起不来,当时是因为在百度下载的镜像,第二次是从官方下载的,试了也不行,后来怀疑是网络问题,下载过程中有文件丢失,最后下载完成后校验MD5与官方MD5一致的时候,再升级就正常了。你这种两个分区都被刷没了,选择6是没办法自己刷机成功的,这个地方的文件不是镜像文件,这些文件只有原厂内部有,我们是无法下载到的。如果设备在保的话,联系售后吧!
bailufengling
我遇到过一次,硬件故障了,找别人修了RTOS,试过也不行,tac说硬件故障,如果在保的话开case确认一下,硬件故障就走RMA更换
Xin Lei
有可能你的IOS问题,下载记得使用MD5校验一下~
pxhen
Boot Loader Menu
思科2504和5508无线控制器,均,均,均不支持这个模式下恢复AES文件的,很多人再找个模式下折腾,最后导致双分区系统都提示BAD IMAGE,
AES文件是加密和压缩的,仅仅支持WEB下升级。
如果撸主能找到解压后BIN的文件才可以在这个模式下恢复系统,试试找思科,开CASE
如有需要,也可私信我进行恢复双系统:lol
peipei.li123
:(楼主现在问题解决了没有啊
快捷链接
