날짜: 07-01-2024 08:29 AM
07-01-2024 01:45 PM - 편집 07-01-2024 01:45 PM
Hello @besss
Does the Laptop have the good IP ?
Do you try to desactivate the Laptop's Firewall ?
날짜: 07-03-2024 08:03 AM
As a result, I suspect a cable problem or a laptop connection adapter problem.
Ping is normal when you set speed 100 on the interface.
Is it a cable issue?
날짜: 03-17-2025 02:25 PM
Hello @besss
if the ping works when you set the interface speed to 100M, it strongly indicates a cable issue
03-17-2025 09:19 AM - 편집 03-17-2025 09:21 AM
In some cases, the LAN connecter supports up to 100mbps, and the LAN cable may be defective.
1. Test the speed using a new LAN cable
Bad LAN connecter if new LAN cable supports 1 gbps.
2. If you can support up to 100mbps even if you change the LAN cable, replace the LAN connecter and test it
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
