취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
No ping to vlan1 interface.
besss
C1000 switch ↔ Notebook
c1000 switch is factory initialized
yes/no  : no
en
conf t
interface vlan 1
ip address 1.1.1.2 255.255.255.0
no sh
PC
1.1.1.1 255.255.255.0
After connecting the c1000 switch and the laptop, ping was performed, but the ping does not come out.
4 응답 4
M02@rt37
Hello @besss
Does the Laptop have the good IP ?
Do you try to desactivate the Laptop's Firewall ?
Best regards
As a result, I suspect a cable problem or a laptop connection adapter problem.
Ping is normal when you set speed 100 on the interface.
Is it a cable issue?
Hello @besss
if the ping works when you set the interface speed to 100M, it strongly indicates a cable issue
Best regards
HyeonJoon
In some cases, the LAN connecter supports up to 100mbps, and the LAN cable may be defective.
1. Test the speed using a new LAN cable
Bad LAN connecter if new LAN cable supports 1 gbps.
2. If you can support up to 100mbps even if you change the LAN cable, replace the LAN connecter and test it
빠른 링크
