eelsman
Community Member
Hello guys,
I am working on a personal project and am trying configure this small network on Packet Tracer. I attached a image of what the network looks like on packet tracer, I know the routers are disconnected. I am trying to get PC's on both sides to communicate. If someone can help me to configure the switches so they communicate properly id really appreciate it.
Thanks team,
Erik
Martin L
You need router or layer 3 switch to route traffic between 2 different networks; typically call inter-vlan routing.
Usually router does routing and it is called as Router-on-a-stick, ROAS with several sub-interfaces -1 per subent.
I think you can find some examples of ROAS on here, see https://community.cisco.com/t5/switching/router-on-a-stick-dhcp-not-feed-2nd-vlan/m-p/4063906
or more likely on CLN. https://learningnetwork.cisco.com/s/discussions
Regards, ML
**Please Rate All Helpful Responses **
Leo Laohoo
Please post the homework/schoolwork in the Cisco Learning Network.
angle1234
Community Member
COOL
majed431
Community Member
isp and edge router.pngHow to connect two routers with 2 cables, one main cable and another alternative, and become one cable
Leo Laohoo
@majed431
