ACI Moquery doesn't return a result .
Zarga
Hi Everyone ,
i have a question regarding a simple Moquery .
i´m Triying on a 2 different/separate  ACI Envirement  to get where  a specific Encap-Vlan is used on the fabric and  i´m  using this Moquery :
Apic1#moquery -c fvIfConn | grep 1000
dn : uni/epp/fv-[uni/tn-customer1_ten/ap-video_ap/epg-video1_epg]/node-1110/stpathatt-[video1_ipg]/conndef/conn-[vlan-1000]-[0.0.0.0]
rn : conn-[vlan-1000]-[0.0.0.0]
encap : vlan-1000
Apic2#moquery -c fvIfConn | grep 1000
Apic2#
FYI : Vlan 1000 is configured the same way on both envirement .
the problem is that this Moquery  return a result on one envirement but  doesn´t return any result on the other envirement .
i assume this is somthing with API on the APIC , but i´m not sure .
please , can anyone  tell me or give me  an idea why this moquery doesn´t retun any Result on the APIC2# ? or should i activate somthing on the APIC ?
Best regards and thankyou for your help
RedNectar
Hi @Zarga ,
What you have shown is that in your 2nd example is that there has not yet been an EPG assigned with a static port on VLAN 1000.  You may THINK the configs are the same, but they aren't.
If your endpoints are VMM integration, then you have shown that at site#2, no VM has been assigned to the corresponding portgroup for vlan-1000 on a hypervisor connected to any leaf.
You've just done some troubleshooting.
RedNectar aka Chris Welsh.
Ruben Cocheno
@Zarga
Review again the setup on the second APIC sinc is part of a different setup (cluster).
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
