ACi Multipod Fabric upgrade two Maintenance Groups at the same time
maamann
I want to upgrade two Maintenance groups, those two groups  are for two different pods (1 MG each Pod)
If i start this upgrade via the gui  by "upgrade now" it will start one Maintenance Group immediatly and the other will be queued and processed after the first MG is finished. Seems to be that you can upgrade only one Pod at the same time ?
Have done a additional test with a third Maintenance Group (MG) with more switches from the Pod where the upgrade is already running. In this case the Switches from the third MG start to upgrade immediatly .
Any hints how to do a upgrade in two Pods at the same time ?
Regards Markus
btw. one MG over both Pod doesn´t solve the isse :-(
0 Replies 0
