Circular Dependencies with stretched VRF
JL-CNO
Frequent Visitor
Frequent Visitor
I recently upgraded to Version 4.1.2e for NDO and after doing that we had some out of sync errors. After correcting all of the others, we had one left where we had issues with our stretched schema that has a VRF stretched between two sites. When trying to do the drift reconciliation, I get the following error about some circular dependencies. I am not sure how to fix this without breaking our streched VRF. The sites have local config on the APIC's, for rendezvous points and using their local L3Outs. On the image below, the characters blotted out are the same in every position.
janica
Hi did you fix this?
