Cisco ACI Issue post XML from 4.2 into 5.2
Daniel Blanco
Good Morning,
I have a Cisco ACI in 5.2 version in my LAB with a customer tenant configured. I need make some changes in bridge domain configuration to configure subnet ip address and associate it to outside L3. The customer has 4.2 version and I´ve configured in may lab all the changes and after that I´ve saved each bridged domain configuration in XML format in fact to import into 4.2.
When I´ve tried to import (throught post in APIC GUI) bridge domain XML I´ve found this parameters in XML config that seems is not supported in 4.2 : "userdom".
Does somebody suffer this issue too? Could you help me?.
Many thanks !!
2 Accepted Solutions
Robert Burns
The userdom property likely didn't exist in the BD's object model in the version of 4.2 your customer is using.  Just remove the userdom="" entry from the 5.2 XML config (under the BD section) and it should import fine.
Robert
Just to close the loop, I confirmed this in the object model of both 4.2 vs. 5.2.  You'll see the userDom property was added between the two versions.
Regards.
Robert
Robert Burns
Robert
Regards.
Robert
