Cisco ACI simulator question
nicmyswitch
I am very new to Cisco ACI. I have configured the Cisco ACI simulator 4.2(7l) with all the defaults. I followed the first time set up and successfully registered 2 leaf switches and 1 spine switch. All are active and healthy. However, I want to change one of the leafs to be remote. I tried clearing the config and starting over. When I click to register a leaf, I check off the "is remote" box hoping that it will force this leaf to be a remote one. It never completes registering and continually shows "discovering" under the action column.
2 questions: Is it possible to add a remote leaf to the simulator? If so, how do I do it?
RedNectar
Hi @nicmyswitch ,
Welcome to the forum.
I'm sad to say that the answer to your question 1:
is unfortunately - "No"
So Q2 doesn't get a ticket to start being answered.
But setting up a remote leaf is a lot more work than checking the [x] Is Remote option!
You must first configure L3 connectivity between your spine(s) and the remote location!  The official Cisco guide is pretty hard to read, so I stole this picture from here
RedNectar aka Chris Welsh.
RedNectar
Hi @nicmyswitch ,
Ok, that is what I was thinking but thank you for confirming. Appreciate the help.
tomy.tim
EnglishEnglish
ˈiNG(ɡ)liSHˈiNG(ɡ)liSH
Double-click
Select to translate
Hi @nicmyswitch  , I just made a tutorial with the latest version of cisco aci simulator 6.03d, maybe I can help you. If you have any questions don't hesitate to ask. Link: https://community.cisco.com/t5/application-centric-infrastructure/installation-guide-for-cisco-aci-simulator-6-0-3d/td-p/4991325
Tomy Tim
