Cisco ACI vPC Port-Channel Numbering?
Robin Martinez
It appears, at least with our configuration, that the port-channel numbers across the leaf switches in a vPC pair tend to not match.
For instance, a given vPC might be Port-channel7 on Leaf1 while it's Port-channel3 on Leaf2. Sometimes they do align but more often it seems they don't.
I understand that the numbering is really only locally significant, so it doesn't really matter for forwarding but it does make monitoring and troubleshooting a bit complicated when using the CLI or SNMP.
Is there any way to make sure these always align? Or are they just randomly generated every time they're configured/rebooted? There was nothing obvious that I could find.
7 Replies 7
RedNectar
Hi @Robin Martinez ,
Someone who has gone down this rabbit hole before may have a better answer, but my belief is (after 10yrs of configuring them), the PortChannel numbers are allocated at the time of creation and will stay the same through reboots/upgrades etc. Delete the VPC and re-create it it is likely to get a different PC number.
However, I've never documented or tested this, so I can't say I'm 100% sure.
RedNectar aka Chris Welsh.
As far as I have seen so for, you are absolutely right @RedNectar !
I have put many VPC Port-Channels into consideration of monitoring systems before.. and the number does not change on reboots.
However is chosen for you upon creation and cannot be chosen manually.
BR Jules
Have you seen the scenario where the port-channel number is not matched between the vPC switch pair?
For instance, I'm looking at one right now where the vPC ID matches (of course) but it's Port-channel2 on Leaf1 and it's Port-channel3 on Leaf2 which seems odd. Everything works from a data plane perspective just as you'd expect.
You bet. About 90% of the time the port channel numbers are different on each leaf.
But here's a tip if you want to find the VPCs in the Inventory, navigate to Fabric > Inventory >> Pod1 > Leaf-nnnn > Interfaces > PC Interface and you'll find your VPC. This is MUCH easier than Fabric > Inventory >> Pod1 > Leaf-nnnn > Interfaces > VPC Interfaces > nn > > Holy_sh_t_which_number_do_I_pick?  and then finding your VPC after eventually guessing the right number.
Another tip is to follow my naming conventions to find the relevant VPC easily by name. E.g. a VPC named L1201..1202:1:35_VPCIPG defines a VPC on interface 1/35 on Leaves 1201 and 1202
That's perfectly normal. Take 10 deep breaths and learn to live with it!
Yes, all the time, that is completely fine, just as @RedNectar already explained.
Robin Martinez
The mismatch between port channel numbers is certainly annoying but we can easily deal with it.
The more curious part to me is the fact that they change after a reboot in our environment but seemingly not in others. I did go back and verify that after we rebooted a leaf last month for maintenance, all of the port channel numbers rearranged. Po6 became Po2, Po1 was suddenly Po4, etc. The vPC IDs do remain consistent.
I guess that will need to be a TAC case.
@Robin Martinez ,
Thanks for this gem. I'm going to play around a bit more and see if I can make it happen (when I get a spare day to play)
