CSCuy16355 - Support traffic routed within same l3extInstP using catch-all 0/0
dland
Which ACI software release version would fix the issue below?
CSCuy16355
Description
Symptom:
Traffic is policy-dropped between two L3 devices configured under same L3Out. (Transit routing within same L3Out). Can be verified by issuing "show logging ip access-list internal packet-log" and seeing the packets that are dropped due to policy.
Conditions:
When doing transit routing between two devices configured under the same L3Out and one External EPG with only 0.0.0.0/0 defined. This includes using dynamic or static routing. Providing/consuming the same contract under that External EPG does not resolve the issue.
Workaround:
Put the more specific subnets that are communicating as subnets under the External EPG so that the source/dest can be matched against rules appropriately.
Another workaround involves placing a 0.0.0.0/1 and 128.0.0.0/1 under the Subnets field of the l3extInstP (L3out EPG) will allow traffic to transit.
Another option is to to go unenforced in the VRF.
Robert Burns
This bug is not yet resolved.  Once it is, the integrated releases will be populated.
Robert
Robert Burns
Robert
lindawa
Before APIC, release 2.3(1f), transit routing was not supported within a single L3Out profile. In APIC, release 2.3(1f) and later, you can configure transit routing with a single L3Out profile, with the following limitations:
  • If the VRF is unenforced, an external subnet (l3extSubnet) of 0.0.0.0/0 can be used to allow traffic between the routers sharing the same L3EPG.
  • If the VRF is enforced, an external default subnet (0.0.0.0/0) cannot be used to match both source and destination prefixes for traffic within the same L3EPG. To match all traffic within the same L3EPG, the following prefixes are supported:
    • IPv4
      • 0.0.0.0/1—with External Subnets for the External EPG
      • 128.0.0.0/1—with External Subnets for the External EPG
      • 0.0.0.0/0—with Import Route Control Subnet, Aggregate Import
    • IPv6
      • 0::0/1—with External Subnets for the External EPG
      • 8000::0/1—with External Subnets for the External EPG
      • :0:0/0—with Import Route Control Subnet, Aggregate Import
  • Alternatively, a single default subnet (0.0.0.0/0) can be used when combined with a VzAny contract. For example:
    • Use a VzAny providing contract and an L3EPG consuming contract (matching 0.0.0.0/0), or a VzAny consuming contract and L3EPG providing contract (matching 0.0.0.0/0).
    • And use the subnet 0.0.0.0/0—with Import/Export Route Control Subnet, Aggregate Import, and Aggregate Export.
The external documentation was also updated yesterday by the doc team
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/kb/b_KB_Transit_Routing.html#concept_CBBCBA5750D84E4BB49CD727FDCF547A
The enhancement bug CSCuy16355 is also updated with above details, please feel free to check out.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy16355/?reffering_site=dumpcr
This is great news!   Is this also fixed in ACI 3.0 and, if so, which versions?
-Craig
Craig, transit routing within single l3out would work in any release later than 2.3(1f) with above workaround applied, and it's supported. HTH.
