Does ACI MultiSite CloudSec requires MACSec to be implemented?
SIMMN
Referencing Cisco CloudSec document, it seems like MACSec needs to be implemented within each site fabric...I can see both CloudSec and MACSec used concurrently to ensure encryption for data in-transit within the fabric and cross fabrics. I do not feel macsec is necessary if all I want is encryption for inter-site communication and I do not need the encryption within the Fabric. But I could not find any doc gives me the answer...
So does MACSec need to be enabled/implemented in each site fabric in order to do CloudSec in ACI Multi-Site environment?
Sergiu.Daniluk
Hi @SIMMN
No, you are not required to enable MACSec inside the fabric to have the CloudSec functionality turned on.
These can work independent of each other, but can be enabled simultaneously if you wish to have "end-to-end" encryption.
EDIT: to give a little more context, in case of communication between two endpoints, the CloudSec is only available between spines of different sites, and communication Leaf->Spine and Spine->Leaf remains unencrypted. If its a requirement to have it enc, then MACsec can be enabled.  Starting with version 5.1(1), in case of communication EP(site1)->L3Out (site2), the CloudSec will be between Leaf(site1) -> BL (site2)
Stay safe,
Sergiu
Sergiu.Daniluk
Hi @SIMMN
Stay safe,
Sergiu
Thanks for the information!
