Fault F2547 - Specified node not present in the specified pod topology/pod-1/node-604
We had a leaf (leaf604) in pod3 but it was removed (removed from controller).
The leaf was moved to a different pod (pod1) as leaf206, and its up and running.  But I get a lot of messages:
Specified node not present in the specified pod topology/pod-3/node-604
How can I get rid of these fault messages?
We upgraded the apic's and switches to 3.2.3n today, but we still have these faults.
Most likely we did something wrong when the leaf was removed.
GS
The solution for this was to open a TAC, and letting them run testapi to remove the faults.
Geir
micgarc2
Sounds like https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg77689/?reffering_site=dumpcr but should be fixed in 3.2(3n). Open a TAC case and we can take a look.
yes, I've also read that bug.  But hoped it would be fixed in this release.
I will open a TAC, and post the solution when it's fixed.
Thx Geir
Geir
