L4-L7 virtual IP forwarding _Cisco ACI_Border leaf perspective
NDP
When I run command " show endpoint IP " for one of Virtual IP ( Direct server return expected) which was added into L4-L7 virtual IP under EPG, output had not shown any interface on Border leaf switches.
would like to know if Border leaf or any other leaf doesn't contain the required information ( tunnel interface to other leaf), how does the forwarding work for these IPs
And, how can We identify which leaf the endpoint is currently learning through from CLI
This is the output I see when I run " show endpoint ip X.X.X.X on one of Border leaf switches"
Legend:
s - arp O - peer-attached a - local-aged S - static
V - vpc-attached p - peer-aged M - span L - local
B - bounce H - vtep
VLAN/ Encap MAC Address MAC Info/ Interface Endpoint Group
Domain VLAN IP Address IP Info Info
Tenant:VRF X.X.X.X unspecified
here, interface is " Unspecified"
0 Replies 0
