Looking for advice on defining external networks for L3Out
SIMMN
I was asked for this question below and I do not know the answer...
What would be the downside of using 0.0.0.0/0 as the external network subnet for all the L3Out external EPGs?
Here is some background information related (to keep thing simple, lets say it is a single pod/single site ACI): Say a company uses ACI with OSPF and static for their L3Out (L3Out-OSPF). The L3Out-OSPF External EPG subnet is configured as 0.0.0.0/0 with default control settings. Then they bought another company who is using EIGRP...So to inter-connect ACI with the new aquisition network, a new L3Out with EIGRP (L3Out-EIGRP) needs to be configured. There is no transit routing needed for ACI. So here comes the question: whatif "0.0.0.0/0" is entered again as the external subnet for this new L3Out-EIGRP external EPG within the same VRF?
I never tried this setup myself but I believe functionnality wise, it would work... However, what would be the downsides then (shot-term and long-term wise)?
Thanks!
ecsnnsls
ecsnnsls
Hi @SIMMN ,
You can refer to this document,
https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/application-policy-infrastructure-controller-apic/215016-overlapping-subnets-on-l3outs-in-cisco-a.html#anc4
section "Fabric with 0.0.0.0/0 prefix declared as external on multiple external EPGs"
Thanks for the link! Even the doc was created using ACI v3.2, it was still an interesting read actually. Two take aways:
  1. When deploying L3outs, separate EPGs in the same VRF, should not have overlapping subnets marked as 'external subnet for external EPGs'.
  2. With 0.0.0.0/0 used as subnet in L3Out EPGs, communication would work but it could lead to contract bypass for inter-EPG traffic...
But here is a little bit reality check, how many ACI fabrics in production are actually using specific contracts for inter-EPG instead of using vzAny Tenant/VRF wide?
