Routing between EPG in same VRF
I must be missing something.  The case should be easy.
Running ACI in multipod, with 3 POD's.
In POD1 I have server1 connected to EPG1 and leaf201 with static port vlan 10 towards the server.
In POD1 I have EPG2 and leaf201 with static port vlan 20 configured.
In POD2 I have server2 connected to EPG2 and leaf401 with static port vlan 20 towards the server.
Both EPG's belong to the same Application profile in the same Tenant, and same VRF.
I have configured vzAny in the VRF so traffic should run good between the EPG's.
EPG1=BD1=vlan10 (subnet 10.10.10.1/24 unicast routing enabled)
EPG2=BD2=vlan20 (subnet 10.10.20.1/24 unicast routing enabled)
show ip route vrf vrfTest shows both subnets, BD1 and BD2, on leaf 201
show ip route vrf vrfTest shows only subnets for BD2 on leaf401
Traffic between server1 and server2 is not working as I would expect.
If I deploy a static port on leaf401, both subnets shows up in the ip route vrf vrfTest.  And then then traffic seems to work properly.
What am I missing?
Br Geir
It might be that we hit the bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvq25729
We have 4 similar types of the above problem.  2 out the the 4 seems to be fine.
We tried the work around and disable/enable unicast routing worked for 1 of 2.  The last one we removed the subnet, and then added it.
Now all of the 4 seems to be working fine.
6askorobogatov
"I have configured vzAny in the VRF"   There is no such thing.Contract could be between 2 EPGs or EPG and VRF(vzany).
In you case you have no issue with the routing : all BDs are on teh same VRF and (presumably) have L3 interfaces.
So, all you need to worry is security table. So, or you need to have a (1) contracts between  EPGs (using epg-epg or vzany) or (2 ) enable preferred group for VRF and include EPGs or (3) make VRF unrestricted.
See that "vzany configured in the vrf" is inaccurate.  Meant contract under the vrf for all epg's in that vrf to be able to communitcate with each other, rather than having contracts for under each epg.
And the solution for us was to disbale/enable unicast routing for the BD for one of the BD's and delete/add subnet for the otehr.  This helped for both.
Now we see the subnets in the routing table under the vrf on the leaf's.
