Vxlan Based EPG layer 2 extention
Networker0
Hello Team,
When deploying AVE and configuring an EPG as in VXLAN mode (VM learned via Vxlan Encap), if we want to do epg extention (layer 2 extension) to a firewall, how to proceed?
(we added static path to the Fw + Associate its physical dom) , but that didn't work.1.png
Sergiu.Daniluk
Do you have the "Local switching" option for the VMM set to True? If yes, then you need to change it to False.
Cheers,
Sergiu
Hello Sergui,
Thanks a lot for your response. I will try that.
Your answer makes sense because the intra-EPG traffic from the VM is not even reaching the Leaf (where the Firewall is connected).
Maybe my explanation is naive, is there any other good explanation for it?
Br.
