About memory and cpu information using SNMP
conectividade
Level 3
Level 3
Hi folks,
We use the software CACTI to show grafics about memory, interfaces and cpu of our router an switches CISCO, but when we try to sends the comand
snmpwalk -v 1 10.15.17.55 -c public -m memAvailRealm,
to our CSS, it does not return data about memory or cpu. Someone could help us?
infos about our CSS:
CSS01-EXT-SEDE# version
Version: sg0740103
Licensed Cmd Set(s): Standard Feature Set
thanks,
Renato
jaregalado
Level 5
Level 5
I suggest you check if your CSS supports the variable you're polling, if in doubt do a full snmpwalk and check if the variable shows up there. Just be very careful as doing this may stress your device too much with nearly 100% CPU usage and take some time to complete. Try it after hours or on a spare CSS if possible.
Regards...
jfoerster
Level 8
Level 8
Hi Renato,
you've to use snmp v2 for most of the OIDs. Repeat your snmpwalk with version 2c and you will see that you get a lot of more OIDs than using v1.
Nevertheless you can search for OIDs at:
http://www.cisco.com/pcgi-bin/Support/Mibbrowser/unity.pl
Another hint: In the WEBNS you are using the OID tree changed a bit. It's no longer the arrowpoint subtree but the cisco subtree where the CSS is located (valid since 7.4 see http://www.cisco.com/en/US/products/hw/contnetw/ps792/prod_release_note09186a00803a7c04.html#wp182120)
Another thing I rember is that you won't get as much details regarding the CPU and the memory as from a router. I think I read something like that in former posting.
Kind Regards,
Joerg
