ace 4710 load balancing
m.rezzilli
hello guys I have a problem on a 4710 you can not configure a new probe on a server farm and VIP existing without blocking the previous one. some of you has already happened and how you resolved?
dario.didio
Level 9
Level 9
Do you want to add a new probe to an existing serverfarm without interrupting the serverfarm?
This can be done without any problem.
Configure your new probe and add it under your serverfarm:
serverfarm farm
probe new-probe
You can monitor this by doing sh probe new-probe detail and show serverfarm farm detail.
Do keep in mind that if for some reason your new probe fails (fe a misconfig), your rservers in your serverfarm will go down!
HTH,
Dario
grazie dario riprovo, sicuramente ho saltato un passaggio
