ACE 4710 not booting
joasanmu1986
Hi everyone.
I've just run the ACE 4710 and it seems that is booting up well but it stops when 'Setting up dynamic memory size' message appears.
INIT: version 2.85 booting
b4 lspci
1 Cavium device(s) found.
Bringing up NP 0
Downloading U-Boot to NP card 0
Downloading DP image to NP card 0
Starting DP image on NP card on all cores
DP image started on NP card
I've tried to reboot it several times with the same result.
Thank you very much in advance.
Kanwaljeet Singh
Previous instances of same error message indicate hardware issue and hence i would suggest opening a case with TAC.
This message generally comes in A4 code since it had additional memory checks built in which were not there in previous version of the code and when those checks are done, the device may fail to boot.
Kanwal
Jorge Bejarano
Level 4
Level 4
You may require to RMA it
Jorge
