ACE 4710 upgrading software problem
santipongv
Level 5
Level 5
I logged into ACE 4710 to upgrade the image to c4710ace-mz.A1_8_0.bin. I logged in with Admin status and I got the following message, "
ACE4710/Admin# delete image:c4710ace-mz.3.0.0_A1_7a.bin
delete: cannot remove 'c4710ace-mz.3.0.0_A1_7a.bin': Permission denied"
Is this a bug? Is there a workaround? Thank you.
Not applicable
upgrade to lastest ACE image to make parity error go away.
I upgraded to A1(8) and the error message went away. Thank you.
I am getting the same message again when i tried to delete an image and put a new image on.
ACE4710/Admin# dir image:
180784189 May 20 07:52:18 2008 c4710ace-mz.A1_8_0.bin
176933319 May 6 07:10:04 2008 c4710ace-mz.A1_7b.bin
Usage for image: filesystem
714985472 bytes total used
167362560 bytes free
882348032 bytes total
ACE4710/Admin# delete image:4710ace-mz.A1_7b.bin
delete: cannot remove '4710ace-mz.A1_7b.bin': No such file or directory
How can this issue be resolved?
