ACE - configuring script probes (tclsh)
pat1848
Hey guys
I'm looking for exampels about writing script probes for the ACE module.
In the cisco's ACE configuration guide i already found one, but i'd be happy to have a few more. Does anybody knows where i can get some other examples?
cheers
patrick
Roble Mumin
Level 7
Level 7
Tach auch and Hello!
If you check the software section for the ACE Module you will find some ace scripts you can download.
http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/crypto/3DES/lan/catalyst/6500/ace/ace_scripts.tgz&app=Tablebuild&status=showC2A
Viel Erfolg
Roble
