ace connection limit
Charly Coueffe
Community Member
I  would like to limit the overloading of servers and redirect to a backup  server if the first is full. I thought to use  "max-connect" and "backup-reserved".
Now I  would also ensure that if the client is already on the platform he  continued to surf and not be impacted by the max-connect.
The aim is to focus clients on the farm and put on hold the  new.
To know that a client is already  on the platform I thought to use the sticky.
Do not know if  you know of a solution to my need
Charly
5 Replies 5
Peter Koltl
Level 11
Level 11
Do you mean the 'conn-limit' command? I didn't find "max-connect" and "backup-reserved" in the command reference.
Sticky is a good idea. Don't forget to create a resource class for it.
yes, it's conn-limit sorry and backup-reserved is backup-rserver (problem copy paste ).
I already used sticky with insert cookie, but when the server is full the client go to the new server.
Resource class :  you thought the ressource class on the admin context ?
Gilles Dufour
It's not going to work.
A rserver in maxconn state is considered dead and therefore no new connections can be sent to that server, even if sticky entries exist.
Gilles.
Do you know if i can priorised the users that are already connected on the farm.
Charly
Charly, there is no way to prioritized connected users.
Gilles.
