ACE implementacion with servers Lan in other Router
I need help in this topology, I need to design an escenario, where the Lan Servers  are  in other Router, the conexion between the ACE module and the Lan Server is throught a routing protocols using a Layer 3 device like an ASA.
I have a confusion of using a Context in routed mode or One Armed mode. i dont know what is the best option.
I need help.
Attached a Diagram of the  escenarios.
Fidel Gonzalez
Cesar Roque
Level 4
Level 4
Hi Fidel,
This should work in Routed or One-Armed, the only thing you need to be sure is that the response of the servers is going back to the ACE instead of going directly to the client.
You probably will need to use source nat when the ACE sends the traffic to the servers.
Cesar R
ANS Team
--------------------- Cesar R ANS Team
