ACE:Problem with comunication between loadbalance servers and noloadbalance
I have a problem, I've configured loadbalance in ACE Module (Switch C6513). the network of real servers is 10.24.8.0/24 and the network of VIP servers is 10.24.16.0/24. I can access to 10.24.16.12 (HTTP, HTTPS, etc) from all networks except 10.24.8.x (10.24.8.200 to 10.24.16.11, 10.24.8.201 to 10.24.16.11 for icmp is ok, but HTTP, HTTPS is not working) that is out of loadbalance, the default gateway is diferent that balance servers. for the loadbalance servers the default gateway is 10.24.8.5 and for the servers that is out of loadbalance is 10.24.8.1
Thank you
Best Regards
Gilles Dufour
to access your vip from the server subnet you need to perform client nating.
So configure a policy-map to nat traffic coming from the server subnet.
Apply this policy-map to the server vlan and everything will work.
Gilles.
