Showing results forĀ
Search instead forĀ
Did you mean:Ā
ACE routed mode
kalugotla1
Level 2
Level 2
              Two  ACEs LoadBalancers    are setup as active standby    in routed mode.
serverfarm host s1
  predictor leastconns
  probe PROBE_HTTP
  rserver app1
    inservice
  rserver app2
    inservice
class-map match-all s1_CLASS
  2 match virtual-address 10.12.7.11 tcp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
policy-map type loadbalance first-match s1_POLICY
  class class-default
    serverfarm s1
policy-map multi-match POLICY
  class s1_CLASS
    loadbalance vip inservice
    loadbalance policy s1_POLICY
    loadbalance vip icmp-reply active
we had one connection  from client to app2 server
performed a code upgrade  on LB2 ,did a swithover to make LB2 active,.the client connection was still on app2 server
when LB1 was upgraded  and made it primary , the connection was still on app2 .
but after couple mins was seeing the connection on app1 ,instead of app2 .
please help me on this
when
when
you don't have any stickyniss configured. So your connections (also from the same client) can land on any of your two servers. That's a normal behaviour.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
is there anyway I can  get this working ,without sticky configured .for a persistence connection.
what exactly is not working?
Jorge Bejarano
Level 10
Level 10
What you saw it is totally expected behavior.
What happens is that the ACE will keep the connections active and they will be served until the either the connection is closed by the client( by closing the browser) or times out due to inactivity, then if you switchover to another ACE then all "NEW" connections will be handled by the new master ACE since there“s no reason to send the traffic to the previous master ACE because it is not longer the Primary.
Again, this is expected.
Hope this helps
Jorge
