Ace ssl-proxy problem, Online store.
krille_com
Frequent Visitor
Frequent Visitor
Hello!
I have a problem with moving our online store loadbalancing to a Cisco ACE solution from Windows NLB that it runs on now. And also relive the servers from the ssl encrypt and decrypting of sessions.
The load balancing works', as long the session is Http, but when the "customer" comes to the point that i is going to pay. Our shop is jumping over to HTTPs and this is where the problem appear.
The "customer" is getting the certificate right but the site is not displayed = the session to the shop seems to die.
If i have missed something in the config or if someone have any other idea why this dont work for me..
Appreciate any help!
My config:
(at the moment only web5 is in use)
ACE-1/CO-WEB1# show run
access-list ANY line 10 extended permit ip any any
access-list icmp line 8 extended permit icmp any any
probe http PROBE-HTTP
interval 3
passdetect interval 10
passdetect count 2
expect status 200 200
expect status 300 323
parameter-map type ssl SSLPARAMS
cipher RSA_WITH_RC4_128_MD5
rserver host vmware-server1
description testserver1
ip address 219.222.4.180
probe PROBE-HTTP
inservice
rserver host vmware-server2
description testserver 2
ip address 219.222.4.181
probe PROBE-HTTP
inservice
rserver host web5
description testserver from windows nlb
ip address 219.222.4.185
probe PROBE-HTTP
inservice
ssl-proxy service SSL-PROXY-SE
key cert-se.key
cert cert-se.pem
ssl advanced-options SSLPARAMS
serverfarm host WM-ware_servers
rserver vmware-server1
inservice
serverfarm host webtest
description testserver-farm
predictor leastconns
rserver vmware-server1 80
rserver vmware-server2 80
rserver web5
inservice
sticky ip-netmask 255.255.255.0 address source STICKY-GROUP1
timeout 60
serverfarm webtest
class-map match-all VIP-HTTP
2 match virtual-address 219.222.4.178 tcp eq www
class-map match-all VIP-HTTPS
2 match virtual-address 219.222.4.178 tcp eq https
class-map type management match-any icmp
description for icmp reply
2 match protocol icmp any
policy-map type management first-match icmp
class icmp
permit
policy-map type loadbalance first-match VIP-HTTP
class class-default
sticky-serverfarm STICKY-GROUP1
policy-map type loadbalance first-match VIP-SSL
class class-default
serverfarm webtest
policy-map multi-match SLB-VIP-HTTP
class VIP-HTTP
loadbalance vip inservice
loadbalance policy VIP-HTTP
loadbalance vip icmp-reply
class VIP-HTTPS
loadbalance policy VIP-SSL
ssl-proxy server SSL-PROXY-SE
interface vlan 21
description ### ACE OUTSIDE mot FW ###
ip address 219.222.4.171 255.255.255.240
access-group input ANY
access-group output ANY
service-policy input icmp
service-policy input SLB-VIP-HTTP
no shutdown
interface vlan 22
description ### ACE INSIDE Gateway for Web-servers ###
ip address 219.222.4.177 255.255.255.240
no shutdown
ip route 0.0.0.0 0.0.0.0 219.222.4.161
ACE-1/CO-WEB1#
as seen in "show conn" the sessions is established, first when i enter site, and go to payment (jumping over to SSL):
ACE-1/CO-WEB1# show conn
total current connections : 4
conn-id np dir proto vlan source destination state
4 1 in TCP 21 219.222.0.2:49972 219.222.4.178:443 ESTAB
14 1 out TCP 22 219.222.4.185:443 219.222.0.2:49972 ESTAB
11 2 in TCP 21 219.222.0.2:49923 219.222.4.178:80 ESTAB
3 2 out TCP 22 219.222.4.185:80 219.222.0.2:49923 ESTAB
ACE-1/CO-WEB1#
eberhard-schulz
Community Member
Hello Krille
i had the same problem.
The HTT Probe you define will do a check if
the return code is
Now if a user is accessing the hppts site, in the flow there will be an expect status like 404, the ACE now is not establish an sticky connection, cause it think that the flow is not ok.
The only output after ther Certificates is a blank site.
If you change the Probing to ICMP you will be able to access the https site and the connection is sticky. With a litte tool like IE Watch you will be able to see the wrong Status codes.
regards
eberhard
