ACE - Sticky using XFF client value
wriddiford
Community Member
Might be a stupid question  ....but we have a situation where client traffic is LB to our proxy infrastructure , at the LB the XFF client address is inserted into the header and source sticky is enabled. We now need to LB to addtional servers( more than within our proxy infrastructure) downstream from our proxy servers and retain the client sessions, if we use source sticky we will have a one to one relationship with the downstream servers . This we don't want as we want to spread the load across all downstream servers. My question is instead of source IP sticky could we use say the XFF info or something else to stick sessions to the downstream servers.
Kanwaljeet Singh
So your proxy server will need to contact different servers through loadbalancer?
You can use cookies for the same and make the ACE to insert cookie. I haven't tried using XFF header and value for sticky but ACE let's you configure it so it can be tried too.
Kanwal
Note: Please mark answers if they are helpful.
Cheers for that ......looks like we need to play a bit
