ACE20 gre problem
Heine Maring
Community Member
I want to route gre traffic through an ACE20, but it doesn't seem to work. The only thing I configured was an ACL with gre enabled, but the ACE20 seems to drop the gre packtes. The gre traffic is entering via the vlan 561 interface and should be send out via the vlan 472 interface. Source 10.94.32.212, destination 10.94.132.39. The tunnel control traffic on port tcp/1723 is working fine. In the service-policies is nothing configured for the gre traffic.
Can anyone help me?
ACE configuration
access-list ALL line 10 extended permit ip any any
access-list ALL line 20 extended permit icmp any any
access-list ALL line 30 extended permit gre any any
access-list NAT-472 line 10 extended permit tcp 10.94.132.0 255.255.255.128 10.94.133.0 255.255.255.0
access-group input ALL
interface vlan 472
  ip address 10.94.132.2 255.255.255.128
  ip dhcp relay server 10.94.62.158
  ip dhcp relay server 10.94.62.173
  ip dhcp relay enable
  alias 10.94.132.1 255.255.255.128
  peer ip address 10.94.132.3 255.255.255.128
  no normalization
  nat-pool 461 10.94.132.4 10.94.132.4 netmask 255.255.255.255 pat
  service-policy input ALLOW-ICMP
  service-policy input LB-POLICY-VLAN561
  service-policy input NAT-472
  no shutdown
interface vlan 561
  ip address 10.94.83.77 255.255.255.248
  alias 10.94.83.76 255.255.255.248
  peer ip address 10.94.83.78 255.255.255.248
  no normalization
  nat-pool 561 10.94.148.5 10.94.148.5 netmask 255.255.255.255 pat
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.94.83.73
Heine Maring
Community Member
The problem is solved with a reload of the 6509 switch with the ACE module. Probably an interface problem on the ACE due to changes.
