[Ace20] Static PAT with more than one port
doko651985
Hi experts,
i need your help. I have a two-arm Loadbalancer concept for ldap and ldaps.  The LDAP Clients talk to the VIP of the Loadbalancer on port 389 or 636 in the Frontend VLAN of the Loadbalancer. The Loadbalancer distribute the TCP Connection (L4) Roundrobin to the LDAP Server Farm in the Loadbalancer Backend VLAN. For this it is required, that the Loadbalancer perform SRC-NAT and DST-PAT. DST-PAT means the LDAP Clients talk to Port 389 or 636 of the VIP, but the Loadbalancer send the TCP connection to Port 3389 or 6636 to the LDAP Server. This depends on the used port by the LDAP Clients.
My problem is, that i do not know how to configure the DST-PAT on the ACE for 389->3389 and 636->6636.
Could you please show me an example?
BR,
Sebastian
Cesar Roque
Level 4
Level 4
Hi Sebastian,
If I understand this correctly you need to send the traffic from the ACE to the servers in port 3389 and 6636
If this is correct you just need to configure a couple of serverfarms and specified the port number, like this:
serverfarm host sample
   rserver server 1 3389
     inservice
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Hi Cesar Roque
thanks for your reply.
LDAP CLient 1 ---> Loadbalancer VIP (389) ----> LDAP Proxy (3389)
LDAP Client 2 ---> Loadbalancer VIP(636) ----> LDAP Proxy (6639)
If I understand you correctly, th config should look like this?
class-map match-all LDAP
  2 match virtual-address 10.70.136.161 tcp eq 389
class-map match-all LDAPS
  2 match virtual-address 10.70.136.161 tcp eq 636
policy-map multi-match LDAP-Service
  description traffic LDAP VIP
  class LDAP
    loadbalance vip inservice
    loadbalance policy LDAP
    loadbalance vip icmp-reply
    loadbalance vip advertise
  class LDAPS
    loadbalance policy LDAPS
rserver host LDAPPROXYBAM#1
  ip address 192.168.2.129
  inservice
rserver host LDAPPROXYBAM#2
  ip address 192.168.2.130
  inservice
rserver host LDAPPROXYFFM#1
  ip address 192.170.2.193
  inservice
rserver host LDAPPROXYFFM#2
  ip address 192.170.2.194
  inservice
serverfarm host LDAPPROXY
  probe LDAP-3389
  rserver LDAPPROXYBAM#1 3389
    inservice
  rserver LDAPPROXYBAM#2 3389
    inservice
  rserver LDAPPROXYFFM#1 3389
    inservice
  rserver LDAPPROXYFFM#2 3389
    inservice
serverfarm host LDAPPROXYS
  probe LDAPS-6636
  rserver LDAPPROXYBAM#1 6636
    inservice
  rserver LDAPPROXYBAM#2 6636
    inservice
  rserver LDAPPROXYFFM#1 6636
    inservice
  rserver LDAPPROXYFFM#2 6636
    inservice
policy-map type loadbalance first-match LDAP
  class class-default
    serverfarm LDAPPROXY
policy-map type loadbalance first-match LDAPS
  class class-default
    serverfarm LDAPPROXYS
But now I think the load is not distributed correctly any longer.
Example:
Not correct
LDAP Client 1 ---> Loadbalancer VIP (389) ----> LDAP Proxy 1 (3389)
LDAP Client 2 ---> Loadbalancer VIP(389) ----> LDAP Proxy2  (3389)
LDAP Client 3 ---> Loadbalancer VIP (636) ----> LDAP Proxy1 (6636)
LDAP Client 4---> Loadbalancer VIP(636) ----> LDAP Proxy2 (6639)
Correct
LDAP Client 3 ---> Loadbalancer VIP (636) ----> LDAP Proxy3 (6636)
LDAP Client 4---> Loadbalancer VIP(636) ----> LDAP Proxy4 (6639)
My thoughts are so right? How can i solve this?
Hi Sebastian
Please clear the serverfarm counters and then gather a couple of outputs of show serverfarm {name} detail while you send traffic to the VIPs.
Cesar R
ANS Team
