ACS Device Dump
mohammad.ouran
Community Member
Is there a way to get a dump of all the devices on the Cisco ACS?
htarra
Level 9
Level 9
Yes it can. RDBMS synchronization import definitions are a listing of the action codes allowable in an accountActions table. The RDBMS Synchronization feature of the Cisco Secure Access Control Server Release 4.0 Solution Engine, hereafter referred to as ACS, uses a table named accountActions as input for automated or manual updates of the ACS internal database.
Refer to RDBMS Synchronization Import Definitions for more information
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.0/user/guide/ag.html
That is 100% correct, sorry i failed to state that its a ACS 3. not the 4.
