ANM VA - run perl script to obtain and genarate reports.
Paul Pinto
Good day,
We have a customer who has an ANM deployment at a site. This is a HA deployment on RedHat. The customer created a perl script to run off an external host to generate reports. This was acheievd by querying the sqldatabase (dcm_ems). ANM version is 3.2. No problems.
An additional ANM deployment was done on another site. ANM version 4.2. This deployment is the VA edition. They would like to deploy and run the same perl script.
Is this possible on the VA Edition? Even with the RootPatch? Not sure of the level of access the patch provides, or if it is even recommened or would then still allow for the ANM to be supported? If possible, has the sqldatabase structure changed (suppose would need this for the guy's to ammend the script)? How would we obtain the "sqluser" and "sqlpwd" info for the perl script to use?
Appreciate any guidance or feedback.
Thank you in advance.
Paul.
Paul Pinto
Hi esteemed forum members,
Any ideas or feedback anyone?
Thanks.
Paul.
