balancing between 2 ISP
valiangh1
Community Member
Can someone please tell me if cisco PIX 515e is able to balance between 2 Optic Fiber ISP's.
Thank you.
drolemc
Level 11
Level 11
The configuration described in this document can not be used for load balancing or load sharing. Use this configuration for redundancy or backup purposes only. Outgoing traffic uses the primary ISP and then the secondary ISP, if the primary fails. Failure of the primary ISP causes a temporary disruption of traffic.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
