Cache Engine booting problem
sachin
Level 5
Level 5
Cache Engine is getting hanged up and is not communicating. After restarting 3-4 times the same error message(every time) I got is- --
open failed: /flash/image errno=0
Error loading file: errno = 0x0.
Can't load boot file!!
Further if i have to install fresh new bin file then what bin file i shall install,
CE model no. is CE-550 and software version was 2.31
thanks
wong34539
Level 11
Level 11
The CE 550 has been listed under the End Of Sales / End of Life Plan . So I am not sure of the latest release.
http://www.cisco.com/en/US/products/hw/contnetw/ps546/index.html
The latest release for the Content Engine is 3.1.1
http://www.cisco.com/univercd/cc/td/doc/product/webscale/webcache/ce31/311_rn.htm
You could use the Software Advisor to find the file that best suits your requirements.
