cache engine
htmltobing
Hallo,
Can I configure ce 507 CDN as a cache engine, if can please give me an example.
thanks
didyap
Level 11
Level 11
The CE-507-CDN is a Content Engine with 1 18-GB disk drive. Since I am not able to figure out what exactly you would like to configure on the cache engine, the link to the support page is given below. You could choose the appropriate sample config from the same.
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Hardware:Cisco_Content_Engine_500&s=Software_Configuration
tgrevers
Depending on which version of code is on your 507-CDN, you may have a device that is built to only run CDN, and not operate as a cache. This is not a problem. To correct this, you will need to upgrade the image on this device to at least v4.2.
Check to see which version of code is on the device, then run the needed upgrades to at least v4.2, from there, you will have cache functionality, as well as CDN functionality.
-Ted
