CE and IP Spoofing
f.franceschini
Hi All,
I've configured a CSS 11800 an a CE 7325 to do reverse proxy caching. I need the origin server to see only the clients IP so I've enabled the "wccp spoof-client-ip enable" to mask the CE requests.
It seems that it's not enough as I see the CE requesting content from the origin web server.
Any idea?
Thanks in advance
Fausto
8 Replies 8
Gilles Dufour
do you have the 'wccp version 2' command in the config as well ?
Gilles.
Hi Gilles,
we configured WCCP ver 2 even if the CE is interacting with a CSS and not with a WCCP enabled router.
The ACNS version is 5.0.3 (build b5)
Here is the current configuration:
hostname CE7325-1-LAB-MDV
http proxy incoming 80
http l4-switch enable
interface GigabitEthernet 1/0
ip address 10.216.52.50 255.255.255.128
exit
interface GigabitEthernet 2/0
ip address 10.212.4.45 255.255.252.0
exit
interface FibreChannel 0/0
exit
ip default-gateway 10.216.52.126
no auto-register enable
no bypass load enable
wccp version 2
rule enable
rule action use-server 10.216.52.200 80 pattern-list 1 protocol all
transaction-logs enable
username admin password 1 bVmDmMMmZAPjY
username admin privilege 15
authentication login local enable primary
authentication configuration local enable primary
Thanks in advance
Fausto
Hi Gilles,
even after upgrading the CE to the ACNS 5.1.3 we observe the same behaviour. The CE still requests the contents using its own address and not the client's.
Thanks in advance
Fausto
Fausto,
apparently with version 5, they introduced a new command
agra(config)#http l4-switch ?
enable Enable L4 switch redirection.
spoof-client-ip Client IP spoofing
Could you give it a try.
Gilles.
Hi Gilles,
I tried the command you suggested but it seems it doesn't work.
Anoter question: how can you manage the presence of more than one CE, is there a way to configure some sort of cluster?
fausto
Fausto,
I tested the config myself this week-end and it worked for me.
Could you explain what is not working exactly.
Gilles.
Hi Gilles,
in my case I still see requests to the web servers coming with the CE source IP and not the client. It seems the CE doesn't spoof the IP.
Do you think the problem could be in the rule I configured?
rule enable
rule pattern-list 1 dst-ip 62.13.171.20 255.255.255.255
I used this rule to make the CE call the WEB servers in a balanced manner; the vip 10.216.52.200 is managed by the CSS.
Could you please send me your configuration so I can compare it to mine?
Fausto
indeed, when a rule is enable it seems to break ip spoofing.
I'm not sure yet if this is expected behavior.
I'm checking with our developpers.
Gilles.
